Author Topic: jumping ...missing and backfiring  (Read 18791 times)
Offline billy192
    • Shermonkel
Re: jumping ...missing and backfiring
« Reply #15 on: March 26, 2015, 02:21:04 PM »
Thanks Sparrow1
they are the original that have been on the bike for the past 2 years when it ran great. i will still check to see if i damaged any of them putting them back on.
Billy
Billy
Offline billy192
    • Shermonkel
« Reply #16 on: March 27, 2015, 08:20:54 AM »
just tested the coils they look fine. each one registered 10.3 to 11.4 and the new NGK caps were all at 4.9.
next i am going to strip the carbs and check in case some dirt got in them while they were off the bike. i will also look at the rubber boots while i can.
Billy
Billy
Offline ka-ja
  • ken
  • yoshi 460
« Reply #17 on: March 27, 2015, 04:33:06 PM »
Hi,
    Still reckon you have an air leak between carb and the cyl. head----Ken
nice bike,nothing in the bank
Offline billy192
    • Shermonkel
« Reply #18 on: March 28, 2015, 08:00:00 PM »
well just spent a fortune with DS for new rubbers and new clips :-[ :-[
lets see
Billy
Billy
« Reply #19 on: March 29, 2015, 01:43:27 PM »
Billy
If it were me sit back and look at what you have done.B4 fixing the plug you were happy with her yes?So you have removed the airbox,carbs,disconnected all the wiring blocks took the engine out stripped down to the head off and fixed your valves and plug thread and cleared all swarth yes?Now reassemble VALVE TIMING SPOT ON?All connectors checked,carbs back on no problems went on fully home?I assume you did not leave shite fuel in the carbs?So still does not run right ask yourself why not.Coils etc don't just stop working overnight(though some would disagree) otherwise every winter I would need new ones for my two they stand for best part of 5 months.
I wish you the best
Bitsa
« Reply #20 on: March 29, 2015, 06:58:29 PM »
I was looking at this last week but couldn't reply as my temp wi-fi link wouldn't keep me on long enough to write it, I was over in your neck of europe bitsa but a fair way from you in annecy/moutier/frejus area and drove back yesterday.
My initial thoughts barring any simple air leaks/fuel jet blockages etc are those that Bitsa says above in bold, are you sure the cam timing is right?
If the cam was timed a little in advance of spec then it would step toward what you have experienced I'm not saying it's the only thing you should look at but you'd need to be confident it's right to avoid chasing your tail through lots of other stuff.
I know this ignores the exhaust cam timing (which would also be out) but if you run the inlet cam in advance of the correct setting it would have the effect of compromising low speed running to potentially give gains at higher rpm, similar to using a wild cam in a race engine.
The inlet cam should open at low rpm late enough to prevent any mixture being drawn in and being fired by the wasted spark on the exhaust stroke of the engine, this would happen (the small amount of mixture being ignited and come out of the inlet because the valve is open too far) if you have got the cam in advance of the correct timing.
I was trying to think of a way to check the timing without removing the engine and the logical way is to use a degree disc on the crank to measure against spec if you are familiar with the method.
If not you could try a rough and ready setup to see if you get an improvement by backing off the inlet tappets to twice our three times manual spec's (should retard the inlet valve timing) and retarding the whole ignition plate by about 5 degrees (this would move the wasted spark further away from the inlet charge entering the cylinder) and then run the engine to see if the spitting back has been reduced, this is not for a solution overall but to see if the motor will run smoother at low rpm and give you more reasonable cause to remove the motor if required.
See what others on here think, please shout if anyone disagrees with the above.
Offline billy192
    • Shermonkel
« Reply #21 on: March 30, 2015, 08:46:27 AM »
thanks Guys,lots for me to look at. when i put the cam back in i had the timing mark on the crank and the notch on the cam lined up. is there another way. surely if the notch is pointing up and the two lines are horizontal also 1-4 is at T then the cam is timed? or am I wrong? i can just about see the notch in the cam with the engine in the frame.
Billy
Billy
« Reply #22 on: March 30, 2015, 03:30:13 PM »
That's correct; the 2 marks on the cam gear level with top of head while at TDC
Offline fisjon
« Reply #23 on: March 30, 2015, 04:45:14 PM »
Hi 'Billy'
This is john here from Caerphilly, is this the beast that I did the carbs for? If so then I can say that the carbs were definitely on the bike tidy, the carb balance correct and the ignition timing and points dwell spot on.
I do remember that the engine had a habit of racing up on it's own for no apparent reason and a it came back down when it felt like or after you blipped the throttle a few times, that might have been the fuel supply as it was a temporary arrangement at the time.
The only other thing I can think of that would cause that is a sticking advance retard mechanism. You say that you have checked this out, but did you remove it and clean up, lube and re-fit or did you just check with a strobe. If you checked with a strobe it still might be temporarily jamming up and that would cause misfire/popping but this would be on all fours pots. The other thing is the springs, are they the correct ones as I seem to remember they are different strengths.
The problem with these old Honda electrics is that they have a very weak spark to start with, if there is an electrical fault it won't take much to upset the spark output.
Just a thought.
john
Offline mihai.i
« Reply #24 on: March 30, 2015, 05:49:50 PM »
I had almost the same problem. Turn out there was air leak between carbs and admission. Also, i had problems with my points.
After new o-ring for the admissions, timing and tappets tune up all is good!
Also check for the following:
- good battery
- problems with the fuel line
- good sparks and spark plug
- good air filter
- carb sync
« Last Edit: March 30, 2015, 05:57:06 PM by mihai.i »
Honda Cb550k 1978
« Reply #25 on: March 30, 2015, 09:44:58 PM »
Yes as you say Billy with the marks as you describe, after i've done that i'd install the cam chain tensioner and then turn the crank (plugs out) with a spanner at least two rotations forward and recheck that the horizontal lines are still in line with the cam carrier joint to make certain that it is correct when in the fully assembled running condition.
As the other posts have said, if the ignition stays at advance and doesn't go back to base/static setting at low rpm then you'll have a similar effect with a conflict of inlet valve opening and spitting the first part of the intake charge back out of the starting to open inlet tract.
Offline billy192
    • Shermonkel
« Reply #26 on: March 31, 2015, 08:32:46 AM »
thanks Guys, yes john (Caerphilly) the bike ran great the intermittent revving settled down after 400 or so miles the out popped number one. well i have a nice 4 day stint to sort this out thanks to the forum i have a list of stuff to change / clean adjust. i will post my findings and hopfully sort this out.
Billy
Billy
Offline billy192
    • Shermonkel
« Reply #27 on: April 10, 2015, 07:57:38 PM »
Ok so today i put on the new carb to head rubber and new carb to air box rubbers with new clips...and still the same :(
as a last resort new condensers and points and checked the auto advance unit put all back together timed with a bulb (static) and fired her up and perrrrrrrrrrrrrrr like a pussy.  8)
will take her for a blast in the morning gut great no miss no popping
Billy
Billy
« Reply #28 on: April 10, 2015, 09:52:32 PM »
The thing to do now is refit the old condensers to determine whether the fault was caused by the points or the condensers.
I don't blame you if you don't feel like it though.
Offline Sparrow1
« Reply #29 on: April 12, 2015, 06:26:39 PM »
Pleased for you Billy.
  LEAVE IT! If it now runs sweetly...😉😄 Go out and have a bit of fun her!
  Nige.
