Project Board
CB350F Restoration by royhall (NOW FINISHED)
3
4
5
14
Topic: CB350F Restoration by royhall (NOW FINISHED) (Read 89890 times)
Re: CB350F Restoration by royhall
Reply #30 on:
May 22, 2015, 05:39:40 PM »
Problem you got is I think Black is the thickest shell so if the pins are worn you may have problems. I wouldn't bother with the casing holes as unless the shell has spun there is no wear and at least its not like Fords where they have a standard hole size and a plus 10 thou hole size for if the boring machine hiccups then they dont scrap a block---makes buying parts a b*tch
I have built several 500 and a couple of 750's(way back when) engines with all black shells and run in carefully with no problems and i know the race boys used to go one thinner than stated to get more oil round and not need bedding in.
When you work out the difference between smallest pin largest hole as against largest pin smallest hole i seem to remember you are in the tollerance range of a grinding machine anyway
royhall
Keep biking I'm not quite bankrupt yet
Reply #31 on:
May 22, 2015, 05:45:28 PM »
There's the AA Blue shell that's available in the States.
Reply #32 on:
May 22, 2015, 05:52:46 PM »
If they are available, use them mate, only ever seem blue colour on Wing shells, but then never had to fit shells to a 350 or 400 either!!
Reply #33 on:
May 22, 2015, 06:01:25 PM »
This place sez they have 7 AA shells in stock but $15 each(also 5 B 13316-333-003 but no black)
http://www.hondarestoration.com/photodetail.asp?hrPart=13314-333-003
Last Edit: May 22, 2015, 06:04:44 PM by Bryanj
royhall
Reply #34 on:
May 24, 2015, 07:56:54 AM »
Hi all.
More on the shells later when I get a chance to measure up. Been using the fine weather to get the engine painting out of the way. Had all the castings bead blasted then a really good clean out with heavy degreaser and a flush in hot water. Got everything masked off ready.
Spray painted everything with Simonize aluminium finish engine enamel. Looks okay and a nice finish. It sprays really well without runs etc and dries fully within 30 minutes. Gave everything 3 coats.
Wife's away this weekend visiting daughter No.2. So whilst theres the opportunity to get it all in the oven to cure.
What she doesn't know she cant complain about. Got in real bother last time with the 750. Had a price to stove enamel the castings £225 plus VAT so that's a big saving. £21 for the paint, £15 for bead blasting, £12 for degreaser. Well pleased with the results. Next installment will be the engine going back together.
Last Edit: May 24, 2015, 07:58:40 AM by royhall
royhall
Reply #35 on:
May 24, 2015, 01:59:37 PM »
Okay. Back to the shells. Have done some very careful measurements. Have torqued up the crankcases and measured the two outside journals with telescopic gauge and micrometer. I agree with Honda they are B&C. Cant check the inners with a telescopic gauge as I cannot get the gauge out after the measurement. An air gauge would be perfect for this job. So will assume the other three journals are correct.
Measured the crank journals, mains and big ends, and they are all exactly 1.2590" not even a tenth thou in them. Checked for taper and ovality and all bang on. Top marks to Honda for managing to build a crank to those tolerances. Impressive. Torqued up the conrods and measured them, they are as Honda states all No.2s
Checking the tolerances in the manual with my measurements I get the following, Mains 1-3 are green 4-5 are brown. Big ends are all green.
Using the crank etchings, Mains 1-brown, 2-green, 3-4-brown, 5-black. Big ends are all yellow.
Colour coding on existing shells is still clearly visible (paint on side), Mains 1-4-brown, 5-black. Big ends all brown.
What an utter load of nonsense that lot is. Very little correlates together. Either Honda have put the wrong shells in this engine or (more likely) it's been rebuilt before and the mechanic used the wrong bearings (or whatever they had on the shelf). Well I trust my own judgment and measurements so am going with the top line which is what the ACTUAL measurements are. In any case if you go from the largest bore size to the smallest crank size there is only 1 thou and 8 tenths difference anyway. Just goes to show it's never wise to just trust somebody else, always check and double check. Mistakes get made.
Decision made now so I am going to get the shells ordered tomorrow. I've been so careful with this I am confident I am right.
Checked through the rest of the engine parts and all appears to be in extremely good nick. All the bearings feel like new, no wear on the selector forks etc. Am very impressed with the engine in general, there are some very well made parts in there. Top marks Honda.
Now the engineers bits finished, time to put the mechanics hat back on (this is where things may get tough).
Last Edit: May 24, 2015, 03:44:07 PM by royhall
Tiny Tim
SOHC Member
Reply #36 on:
May 24, 2015, 06:33:10 PM »
Very interesting read Roy, I look forward to see the finished motor. Might be picking your brain in the future when I have my engine apart. That is a way off yet.
Tim
royhall
Reply #37 on:
May 25, 2015, 09:45:55 AM »
Thanks Oddjob. I was just looking at the paint for further confirmation really, had no intention of using it for replacements. As you rightly say some of it has deteriorated, but some is still surprisingly clear.
I would rush to point out that I am no mechanic and have no experience with Honda four rebuilds at all. One week ago I had no idea about the colour codes on Honda's shells, but Oddjobs superb explanation sorted that out.
The real problem started when I could not really be sure about 2 of the numbers etched onto the crank webs. The first two could have been either 1 or 2, so being the engineer I wasn't settled with that. Then for No.5 the black shells don't exist any more. Then the actual Honda workshop manual does not even mention crank numbers, it advises to measure yourself. I realise that most people don't have the tools to measure a crank to a 1/10th thou, but with my previous job as a Toolmaker, I do (your local engineering shop would measure it for you cheaply). And when measured it revealed that the crank etchings on two of the webs were in fact wrong. If any member that lives near me a Blackpool would like to pop in (kettles on) and re-check it they are most welcome. I am 100% sure the original measurements contain mistakes.
On No.5 it was fitted with a tighter shell (black), and the amount of wear showing on that shell is more than on the others. The thing is though, the difference between the largest diameter case bore to the smallest crank journal is only 1.8 thou, not a lot. You wouldn't want to, but you could probably fit any shell to any journal and with careful running in it would be alright. That's possibly why you can only get Green and Brown now, the middle tolerance bearings.
For Honda to make a crank to such good tolerances is nothing short of superb, but they have Human Beings in the mix and that means mistakes. It is just impossible that Honda turned out every engine to perfection with zero errors. People make mistakes, that's why they put rubbers on the end of pencils.
By the way talking of mistakes, the Haynes manual has a mistake in the shell sizing table, misprinted tolerances.
I'm happy with my measurements, and all you can do is go with what the actual sizes are. If it seizes up first time out I shall fall on my sword.
Big thanks to Oddjob for a top explanation of how the coding system works, cheer mate!!
PS. Just looked, and this has taken pages of the thread. Sorry, Just hope it helps someone else.
Last Edit: May 25, 2015, 11:08:49 AM by royhall
AshimotoK0
Mad Scientist.... more power Igor ! Ù©(̾à¹Ì®Ì®ÌƒÌ¾à¹ÌƒÌ¾)Û¶
Reply #38 on:
May 25, 2015, 12:08:43 PM »
Interesting project Roy and great detail ... I remember my first 400/4 rebuild way back in '81. I got a crank & rods from a breakers in Hull that had done less than 1K miles but I had to get main bearing shells to mach my crankcases so I genned myself up and went into the 5-Star main dealers in Hull for them to check if I had chosen the correct shell colours. None of them had a clue so I just ordered them and fitted them and they worked out fine.
and yes Honda do make mistakes like here:-
As far as I can make out they never corrected it until the 1977 Shop manual.
Last Edit: May 25, 2015, 12:15:26 PM by AshimotoK0
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.†Grace Slick, Woodstock '69 .. In the year of the Sandcast.
royhall
Reply #39 on:
May 25, 2015, 05:02:54 PM »
Now I'm doing it as well. The mistake in the shells table is in the Honda parts book and not the Haynes manual. Bloody humans, keep making mistakes.
royhall
Reply #40 on:
June 19, 2015, 03:17:17 PM »
Finally got back on the 350 project. Have got the black stuff out for powder coating at PX Wheels in Poulton-Le-Fylde. Had him do my 750F2 and he made a cracking job of it. Also says it will be ready Wednesday next week, that's a one week turnaround. Not got it back yet but he only took 10 days to do the 750 so its looking good. The chromings gone out as well, opted for RS Electroplating as he's a forum member and he gave me a good price with a 5 week promise. So until it all comes back its on with the engine.
Quoted me £210 plus the dreaded for the chroming, not too bad as some of it is pretty rusty. The powder coating is £110 and no VAT for the frame plus all the brackets, swingarm, chain guard, battery box etc. Very pleased so far.
Last Edit: June 19, 2015, 03:25:06 PM by royhall
Tiny Tim
SOHC Member
Reply #41 on:
June 19, 2015, 07:20:27 PM »
That's a good price for the chroming and powder coating Roy.
I've still got to go through my chrome bits and decide to keep or replace.
Fork Stanchions are now at Philpots.
royhall
Reply #42 on:
June 19, 2015, 07:33:49 PM »
As you can see from the amount missing from the picture Tim, most of mine was replace. To be honest most of the original brightwork was just scrap. Had a price to do the back mudguard and it was 50% more than a replacement as the rust pits were so deep. My fork stanchions are pretty rusty behind the headlight ears and shrouds as its not chromed but the working area is spot on, so think I will de-rust with a brass wire wheel and just treat them. To be honest I've got to economise somewhere as the rebuild is going to cost way more than the bike is worth
royhall
Reply #43 on:
June 25, 2015, 06:30:59 PM »
Started building up the 350 engine at last.
Just about ready to mate the two halves, but cannot remember how many dowel pins were locating the crankcases. There are two 10mm at the front of the engine, does anybody know if there should be more. Cant find any other holes where a dowel would fit.
Except for that, the engine rebuild is going okay for now. More later.
Tiny Tim
SOHC Member
Reply #44 on:
June 25, 2015, 07:03:15 PM »
Are there two at the rear of the engine.
Part number 15.
http://www.cmsnl.com/honda-cb350f1-four-1974-usa_model434/partslist/E++18.html#results
3
4
5
14
Project Board
