Author Topic: CB750 F1 Project May 15  (Read 46944 times)
Offline Coppertop1234
  • As long as the wife is happy
Re: CB750 F1 Project May 15
« Reply #15 on: May 21, 2015, 07:13:04 PM »
Seat base completed
Quick question
The holes in the base unit, I would presume are for drainage of any moisture absorbed by the foam.
The foam looks grotty where the holes are, so I thought of placing some of that black rubber anti slip stuff you put under doormats.This should allow moisture to escape and improve the visual look when you lift the seat.
It would be a shame to replace all the foam just for the parts where the holes are as it is in excellent
condition
a few pics of finished product
I Love Tinkering with Old Classics
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1962 Triumph 650 Bonneville
1972 Norton Commando
1978 Honda CB400/4
1976 CB750F1
1976 Suzuki GT750 Kettle
1978 Honda CB 750 F1
Married Life No Bikes for a while then
1975 CB Honda 400/4 Restoration
1976 Kawasaki Z650   Restoration
2002 Suzuki GSX1400
1976 Honda cb750F1  Restoration
1978 Honda cb750 F1 Restoration
1977 CB 250 Dream    Restoration
1977 CB400/4  - The last one - Restoration
Offline Green1
« Reply #16 on: May 21, 2015, 07:20:16 PM »
Looks good I always thought the holes were to let air escape from under the cover when the foam is compressed when hitting bumps.
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline UK Pete
« Reply #17 on: May 21, 2015, 08:27:48 PM »
That seat base looks real good, i have read somewhere that you have to anneal the metal tabs/spikes so as they dont snap off when re-bending, however i have done a couple of seats without and all was good
pete
« Reply #18 on: May 21, 2015, 10:15:50 PM »
The holes are to let the air escape when you sit on it.
« Reply #19 on: June 14, 2015, 05:23:05 PM »
Front brake is still sticking
new master cylinder kit
new braided hoses
new piston & seal fitted all movement seems ok
rear retaining arm has free movement on forks
new bolt tension bolt and spring
new pads - pattern could it be they are too thick?
Apply brakes and they don't want to release enough to free spin the wheel
Unless I am missing something ? they should be ok
I have put it down to a senior moment and will have a look later unless there is a something obvious I am missing
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
Offline mickwinf
« Reply #20 on: June 14, 2015, 05:28:23 PM »
try the tiny hole in the master cyl, it looks like a blind hole but should be clear
« Reply #21 on: June 14, 2015, 07:52:02 PM »
Also worth checking the moving pad isn't getting stuck on the excess paint on the moving pad. Often I find removing the paint around the outer edge of the pad with sandpaper, then a tiny smear of copaslip around the outside of it can often help. I assume you didn't have to apply much pressure to get the pad into the caliper housing, as it should almost drop in under it's own wieght.
« Reply #22 on: June 15, 2015, 09:23:40 AM »
From your list the only thing left is the tiny pressure relief hole at the bottom of the reservoir
« Reply #23 on: June 18, 2015, 07:50:58 PM »
It was a  senior moment
rebled the system and front  is working fine
Working on rear of bike and cosmetics now so project 1 is going well
Front end complete
Electrics sorted
Engine nice and smooth fires on the button
Removed the swinging arm to clean and loose the brush paint on frame and surrounding areas
Back calliper freed off and new master cylinder seals ready to fit
Rear wheel stripped ready for detail and repaint
Side panels sprayed rebadged and fitted
Seat recovered and rebuilt
Hopefully in the next few weeks I will be able to post some pics of finished project
Project 2 - Build from Boxes - To become the yellow one
More of a nightmare tying to source parts mainly,without it being an arm and leg
up to date we have had
NOS Front Calliper from Thailand
Switch gear from Italy
Original exhaust from  USA
NOS Headlamp bracket from Germany
Side reflectors and mounts from USA
Front forks from UK
and a share in Dave Silvers
Quite a multi national bike
Just hit a problem with the rear calliper its been over drilled in the bleed nipple so it won't close off and of course the pistons are stuck
We will get there eventually, but suppose its not too bad for 7 weeks to date
Retirement is great fun when you have an hobby like these
Keith Snr
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
« Reply #24 on: July 04, 2015, 06:26:35 PM »
Completed Tank Paint & Decals today
We could not miss this weather apart from a few midges Keith Jnr did an excellent job of striping/painting/lacquering tanks & Cowls as below
We got the Sulphur yellow match, but struggled with candy antares red from our local paint supplier. Instead I choose from swatchs of candy paints available in rattle cans and picked a BMW Candy paint Silver base and Candy Red/Maroon
I don't think its a bad match - Honda badges are just half in for demo purpose on Pictures removing them now before they mark the soft paint
Didn't take any pics of cowls yet
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
Offline Green1
« Reply #25 on: July 04, 2015, 11:37:07 PM »
Tanks look great Keith  8) How petrol resistant is the finish I'v always had problems with rattle cans?
Mick
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #26 on: July 05, 2015, 02:59:49 AM »
Mick
Wow paint looks great you must be so proud Keith. Think the rattle can was used as a 'tester' or swatch Mick, although as I said in another post,  i've seen a superb  Blue/Green  1969 CB750 sandcast done with rattle can's, albeit 1990's formula,
« Reply #27 on: July 05, 2015, 05:22:21 AM »
Cheers for comments - Can't wait to get them onto the bikes
The lacquer is 2 pack and petrol resistant, (we applied 6 coats) so the finish should be nice and solid.
 I didn't know we could get 2 pack in the aerosol,but whole job was done with rattlecans.
The lacquer has the activator inside the can and you trigger the release before shaking and will last usable for up to 20 hrs
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
« Reply #28 on: July 05, 2015, 08:49:22 AM »
They look great, nice job
« Reply #29 on: July 05, 2015, 10:34:35 AM »
That's an amazing job with rattle cans. Never had any luck with them myself, but that's down to my lack of patience I think.
You don't fancy painting my CB350F do you Keith? Am looking for a painter at the moment.
Cheers Roy.
