Author Topic: CB750 F1 Project May 15  (Read 46973 times)
Offline yozzer74
Re: CB750 F1 Project May 15
« Reply #60 on: January 13, 2016, 07:34:14 PM »
Good way to get bearing out is to use a anchor bolt .have a look on utube .I did mine with one straight out no messing
Offline yozzer74
« Reply #61 on: January 13, 2016, 07:40:22 PM »
Offline Coppertop1234
  • As long as the wife is happy
« Reply #62 on: January 13, 2016, 07:50:41 PM »
Cheers - So thats an easier way for future ref.
I Love Tinkering with Old Classics
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1962 Triumph 650 Bonneville
1972 Norton Commando
1978 Honda CB400/4
1976 CB750F1
1976 Suzuki GT750 Kettle
1978 Honda CB 750 F1
Married Life No Bikes for a while then
1975 CB Honda 400/4 Restoration
1976 Kawasaki Z650   Restoration
2002 Suzuki GSX1400
1976 Honda cb750F1  Restoration
1978 Honda cb750 F1 Restoration
1977 CB 250 Dream    Restoration
1977 CB400/4  - The last one - Restoration
« Reply #63 on: January 14, 2016, 07:22:54 AM »
Usually just put a long bar in the centre that is smaller diameter than the spindle and tap it till the spacer moves sideways and then beat sheeite out of the centre race as you are changing the bearing onyroad
« Reply #64 on: January 14, 2016, 08:20:24 AM »
He looks a bit dodgy in that vid. Bearing out, now I'm off to do some robbin. ;D
Offline onethumb
« Reply #65 on: January 15, 2016, 05:16:05 PM »
If it wasn't for the accent I would of sworn that was in India or Cuba.
« Reply #66 on: January 22, 2016, 02:58:23 PM »
Just been toying with the seat logo Silver or Gold
I decided to try silver which was fine, but still hankering "it should be gold"
I found some gold leaf spray, but obviously too late as I had used stencil.
Nothing to loose and time to spare -so I decided to hand paint over silver.
Gold Colour looks fine and with just a bit of detailing to do around the edges and I should be happy
Before
Silver Logo
Gold Logo
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
Offline yozzer74
« Reply #67 on: January 25, 2016, 07:26:37 PM »
Tidy
« Reply #68 on: January 31, 2016, 06:31:44 PM »
Just tried sending a Tyre Info decal to Piki but file is too big
I just can't seem to get the hang of the pm option I click on it and send but it never shows in my sent box.
"I suppose thats why I am called Grandad"
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
Offline Chris400F
« Reply #69 on: January 31, 2016, 06:38:28 PM »
I had the same problem, but worked out what it was.
Select 'Profile' from the choices across the top of the page ('Home', 'Forum', ....).
Select 'Modify Profile' then from the list select 'Personal Messaging'.
Near the bottom is option 'Save a copy of each personal message in my sent items by default'. Tick the check box. Select 'Change Profile' (bottom right' to save changes.
That should do it.
« Reply #70 on: February 15, 2016, 04:52:49 AM »
Before I start the next part, I thought i should ask for advice before doing it the hard way.
I am looking to change the head bearings as mine are about shot. The existing are original bearings and carriers.
I am thinking of replacing with tapered roller bearings, obviously take all old carriers and bearings out.
The question is:
Do I need any special tools to remove / replace the bearings?
Has anyone come across any problems/issues I should be aware of?
Just seen this on youtube and with the exception of metal on metal looks to have some good tips
https://www.youtube.com/watch?v=3H-G111JXbU
« Last Edit: February 15, 2016, 05:31:37 AM by Coppertop1234 »
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
« Reply #71 on: February 15, 2016, 07:53:47 AM »
The ones you take out will be binned anyway so just beat them out with a long drift and hammer but do it evenly all the way round
« Reply #72 on: February 15, 2016, 09:16:02 AM »
These are the instructions that came with my bearings, easy enough as long as Bryan says you keep everything level.
Offline yozzer74
« Reply #73 on: February 15, 2016, 09:56:13 AM »
Offline Chris400F
« Reply #74 on: February 15, 2016, 09:57:43 AM »
Love that final fitting instruction "double check all work".
Don't you always do that?
