Author Topic: changing valve guide seals without removing the head  (Read 6293 times)
Offline UK Pete
« on: June 05, 2015, 06:15:59 PM »
Has anyone tried it using the rope trick , or compressed air?
pete
Re: changing valve guide seals without removing the head
« Reply #1 on: June 05, 2015, 06:20:52 PM »
pete
Have done the rope trick before with a special lever tool on the old mini's.
« Reply #2 on: June 06, 2015, 03:20:15 PM »
That would hold the valve shut but i dont think you will get a tool to compress the springs and get the collets out
Offline TonUp
« Reply #3 on: April 03, 2016, 05:33:51 PM »
overhead valve compressor ... [ Guests cannot view attachments ]
Honda CB550f2 1977
Offline steff750
  • THE POWER OF DREAMS
« Reply #4 on: April 03, 2016, 05:53:19 PM »
Quote
;) yes it does work but its so long ago i cant recall what bike i done it on , not as easy as it sounds, can get a bit a nightmare popping the collets back in, ok if you doing one or two valves, but not the full head it gets a bit of a headache patience is the answer really .
Offline matthewmosse
« Reply #5 on: April 03, 2016, 10:08:22 PM »
I have in the past done valve collets on a cb500 by pressing hard on the tops of the collett retainers with the open jaws of a adjustable spanner, in my own circumstances I was from lack of the right tools and the head was laid flat on a soft wooden bench. I have used the string down the plug or injector hole to stop engines turning over a fair few times, so I cannot see why the 2 should not be combined, I think I can go as far as saying that I have even used the string trick on a sohc Honda, though not one of the 4's.
« Reply #6 on: April 04, 2016, 06:36:00 AM »
More agro and frustration than its worth especialy when the collets disapear into the darkest dingiest part of your workspace, what makes you think you need stem seals anyway?
