Author Topic: Cb750 dual disk upgrade  (Read 34290 times)
Offline El__burro
« on: June 18, 2015, 04:59:22 PM »
http://www.salocal.com/sohc/tech/dual_disks/dual_disks.htm
Having started from the link above
with the intention to upgrade to 2 front disks
I've ended up like in this picture.
Clearly the gap between the wheel and fork is not good.
What's happening.
El__burro
« Last Edit: June 18, 2015, 05:01:17 PM by El__burro »
Re: Cb750 dual disk upgrade
« Reply #1 on: June 18, 2015, 05:45:50 PM »
Looks to me there is a spacer missing and you have the axle nut wrong way round
Bitsa
Offline El__burro
« Reply #2 on: June 18, 2015, 06:14:24 PM »
I didn't use the chrome plate to gain space (as suggested in the post linked above)
Ok for the axle the way around,  I'm going to sort that straight away.
el__burro
« Reply #3 on: June 18, 2015, 06:17:12 PM »
Its the nut that is the wrong way round, it goes on hexagon first
Offline El__burro
« Reply #4 on: June 18, 2015, 07:04:15 PM »
In the Figure below
1 is correctly shown!
I think the issue is with the missing:
2. Front wheel collar.
That should give enough clearance.
Correct?
El__burro
« Reply #5 on: June 18, 2015, 07:32:31 PM »
Looks like you have spacer number 2 missing and as everyone has said, the nut (number 1) is on the wrong way. The hex goes to the inside of the fork leg and not the outside.
« Reply #6 on: June 18, 2015, 09:42:12 PM »
Ben Hiles was a major contributor to the .net site and I have sent out that article quite a few times.
I wonder what he's doing now?
If I could remember his forum name I'd  drop him a line!
Offline El__burro
« Reply #7 on: June 18, 2015, 10:09:08 PM »
Best way to replace number 2.
Just buy one off Ebay or DSS?
El__Burro
Offline dieffe
    • My website
« Reply #8 on: June 18, 2015, 10:27:23 PM »
I have a vague recollection that when I put dual discs and calipers on my K6 in the 70s it actually made the brakes worse if anything. I was told that I should have upgraded the master cylinder as well to cope with the extra fluid that needed pushing.
Is this correct?
Me with said K6, oh dear!!!!
Offline El__burro
« Reply #9 on: June 18, 2015, 10:29:50 PM »
Can't find a "front wheel collar" anyway.
Anyone on this forum has a spare one or a source for me to buy from?
El__burro
Offline MarkCR750
« Reply #10 on: June 18, 2015, 10:34:05 PM »
Is this correct?
Yes, that's correct, the gl1100 gold wing master cylinder is a popular choice, David silvers do a replica item that works well.
PS don't worry we all looked like that in the seventies!
« Last Edit: June 18, 2015, 10:36:17 PM by MarkCR750 »
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Offline El__burro
« Reply #11 on: June 19, 2015, 02:12:31 PM »
front axle collar, has anyone ever attempted to DIH (do it himself)?
#2 in the image below.
Offline MarkCR750
« Reply #12 on: June 19, 2015, 06:03:14 PM »
It would be easy enough to machine up but you would need the correct dimensions, easier to get one from DK breakers or maybe someone on here has one spare?
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
Offline El__burro
« Reply #13 on: June 19, 2015, 07:33:22 PM »
Probably with the following measurements:
Inner diameter
Outer diameter
Total length
I could order one like this.
El__burro
Offline El__burro
« Reply #14 on: June 19, 2015, 08:48:45 PM »
i have taken some measurements,
ID 15mm
OD ?
Length ? (the spacers i have just bought are 21 and 27 mm long)
hopefully it can be done
thanks
el__burro
