Author Topic: Cb750 dual disk upgrade  (Read 34285 times)
Re: Cb750 dual disk upgrade
« Reply #60 on: July 02, 2015, 11:20:41 AM »
The other option you have is to use flexible hoses all the way to the caliper.
That's what I did, from HEL.
Offline El__burro
« Reply #61 on: July 02, 2015, 12:09:34 PM »
Thanks,  I was thinking to use the old bolts instead.
I see what you mean about the modifications to the bolts. (See picture)
Flexible pipes is plan B.
El__burro
Offline El__burro
« Reply #62 on: July 02, 2015, 01:08:17 PM »
Here is what I have achieved so far.
Is the modification to the bolt necessary also for the connection to the hose (as well as the calliper)?
Just need to find how to hold the other side hose and then I'll complete the pipeline.
El__burro
Offline tom400f
« Reply #63 on: July 02, 2015, 02:28:55 PM »
From Bryanj:
Quote
if you are making your own and using original flexibles you need to modify an M10x1 flare nut or it will not seal
I read that as referring to the connection to the hose, only that, not the caliper.
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline El__burro
« Reply #64 on: July 04, 2015, 10:46:34 PM »
it looks like that i am ready to move on the next step.
i have some oil dripping on the fork slider, i guess it comes from under the the gaiters.
ill start a new post for this issue but i will eventually complete this one with a long post with detailed pictures.
thanks a lot to everyone.
el__burro
Offline El__burro
« Reply #65 on: July 04, 2015, 10:50:16 PM »
el__burro
« Last Edit: July 09, 2015, 01:49:16 AM by El__burro »
