SOHC.co.uk Forums > CB750
Crankshaft bearing selection bulletins/ADVICE NEEDED
AshimotoK0:
--- Quote from: Bryanj on June 27, 2015, 07:43:41 PM ---Ash, I think you are overstressing mate. Consider the facts
(1) its an old motorcycle no matter how many new bits
(2) You are unlikely to rag the arse off it in any way that comes close to its original owner(s)
(3) Being honest its probably going to be a sunny high day and holiday bike
(4) No matter what you build it with, run it in nicely(but not too carefully) with lots of oil changes and it will outlast either of us!!
--- End quote ---
Point taken :-[
Trigger:
All built with green
Chris-freckle:
Hi Ash you have probably sorted this now but here's my bit , use the correct bearings as specified by Honda, why spend a fortune restoring / rebuilding your motor using the wrong bits, also use molybdenum disulfide grease when assembling plain bearings.
AshimotoK0:
--- Quote from: Chris-freckle on August 12, 2015, 10:45:00 PM ---Hi Ash you have probably sorted this now but here's my bit , use the correct bearings as specified by Honda, why spend a fortune restoring / rebuilding your motor using the wrong bits, also use molybdenum disulfide grease when assembling plain bearings.
--- End quote ---
Yes cheers Chris, I have all the right code shells now. Sadly, the poor guy who accurately measured my crank journals for me, where I work, passed away on suddenly on Monday. Sounds like you are another pro guy on here with a wealth of knowledge to give us. It's all just a hobby for me.
Ash
Chris-freckle:
This is a hobby for me also, but I am happy share what knowledge I have from my old Honda days
Chris
Navigation
[0] Message Index
[*] Previous page
Go to full version
