Author Topic: Clutch help needed  (Read 4851 times)
Offline mickharrow
Clutch help needed
« on: July 03, 2015, 03:01:16 PM »
Had serious clutch drag so pulled the clutch out today and checked everything and looked ok.
Still dragging badly and the arm that the cable goes into is moving but not a great deal and I have adjusted the centre screw and nut as recommended.the clutch is years old as I am putting together what was a basket case so wonder if a new clutch and springs are in order,opions please
Re: Clutch help needed
« Reply #1 on: July 04, 2015, 02:55:51 PM »
What bike would help
Offline mickharrow
« Reply #2 on: July 04, 2015, 08:32:41 PM »
Bike is cb750 sohc
« Reply #3 on: July 05, 2015, 03:38:24 PM »
Things that come to mind in order of happening
(1) Bad lifting machanism
(2) warped plates steel or fibre + contaminated fibre
(23 grooved outer basket
(4) grooved centre ( both those as in grooved by plates
(5) excess end float on clutch assembly/shaft
Plus there is a "mod" described by Hondaman on the US site about drilling oil holes in the clutch centre
Offline mickharrow
« Reply #4 on: July 05, 2015, 09:57:25 PM »
Many thanks for your reply and help. I will get stuck into your recommendations later this week
Offline neat street
« Reply #5 on: July 14, 2015, 06:00:04 PM »
hi, I am by far not an expert, but did someone also put up a post a short while ago about using synthetic oil??? could this be part of the problem?
John
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
