General > New Member Introductions
newbie
Chris400F:
Don't know if I'd like to stake much on counting them from the picture! And there's not enough of the connector showing to tell.
I was going by the wiring diagram, also on CMSNL: http://www.cmsnl.com/classic-honda-fansite/honda_wiring_diagrams/CM400E.jpg.
fishermanferg:
thanks for the reply the European model is a bit different as I said sent photos of my ignition switch to various shops on e bay nobody had one I have a clymers manual usa one it helps with some info any good news the switch seems to be ok the last time I had it off I obviously didn't tighten it enough it came loose and the plate that sits on top of it had came loose and stopped the key from turning on I thought the switch was done found out the mounting screws had stripped so I could not tighten it up right drilled them through nut and bolt now tight another wee problem the carbs on European models are vb31d tried to get a rebuild kit couldn't find any just wondering if anybody knows if any other vb would work if I needed them another help I needf is it possible to change the fuse box on my bike from the glass fuses to blades
Chris400F:
--- Quote from: fishermanferg on July 07, 2015, 02:20:21 PM ---the carbs on European models are vb31d tried to get a rebuild kit couldn't find any
--- End quote ---
Do you know if these carbs are used on other models e.g. CB400 T/N? If so then you may get what you need from
Cruzinimage at http://stores.ebay.co.uk/cruzinimageuk1484/. He has kits for the CM400 A/C and the CB400 T/N.
I and many others have used him for carb rebuild kits.
--- Quote from: fishermanferg on July 07, 2015, 02:20:21 PM ---is it possible to change the fuse box on my bike from the glass fuses to blades
--- End quote ---
If you can find a part number you may then be able to find if the same part is used on other bikes and then search for
a replacement with blades (there are some for some models). Another choice would be to buy a universal fuse box with
blades then wire it to your connector instead of your original so it will plug in to your loom.
mick:
Hi Fergus and welcome to the forum ;) cheers Mick.
Chris400F:
Fergus, If you haven't already got a carburettor rebuild kit are these any good?
http://www.ebay.co.uk/itm/2-X-CARBURETOR-REPAIR-REBUILD-KIT-80-81-HONDA-CM400T-CM400C-CM400E-UK-/221823024454?pt=LH_DefaultDomain_3&hash=item33a5aebd46
Chris
Navigation
[0] Message Index
[*] Previous page
Go to full version
