SOHC.co.uk Forums > CB500/550
Front forks and other bits, where to buy?
<< < (5/5)
Trigger:
You need a chain and sprocket kit, as you need a front sprocket and the pitch must match.
Noelia:
--- Quote from: Trigger on August 08, 2015, 10:40:46 AM ---You need a chain and sprocket kit, as you need a front sprocket and the pitch must match.
--- End quote ---
Hi trigger that's the set up that wemoto recommended me, to be honest I'm completely lost.
I just want a new chain and sprocket for weekend use and standard as I'm not changing the front sprocket.
hairygit:
Not replacing the front sprocket is a very false economy, unless it is already a brand new one.
Trigger:
+ 1 with Hairy. If you leave the old front sprocket on, it will wear the chain faster (old parts wear out new parts with movement). Better to have a chain and sprocket kit.
matthewmosse:
Another +1 on doing the sprocketts and chain as a set, though I do sometimes run 2 chains to 1 set of sprocketts if the old sprocketts are hardly worn ( genrally if you economise and buy a cheap nasy chain) I wouldn't ecpect to get away with just doing the rear and not the front as the front sprockett turns about 4 times as often as the rear so theoretically will wear out faster.
Navigation
[0] Message Index
[*] Previous page
Go to full version
