SOHC.co.uk Forums > CB350/400
CB400F fork leg length
<< < (3/3)
MikeSB6:
Hello again,
  weirdly, the CB550 yokes put the fork legs closer together than the 400F, so I wouldn't be able to use the wheel I want. Does anyone know if a set of CB750 yokes would fit, and what the leg spacing and diameter dimensions would be?
   Cheers, MikeJ
Norniron:
They cant be 550 yokes then mike!
550 yokes definately are wider than 400s
Norniron:
Just double checked there and centre to centre the 550 is 10mm wider
MikeSB6:
Hello there, thanks for checking- I don't know if the yokes I have are for a CB550F maybe? I don't know if they're different. Anyway, I've got a set of 750 yokes which will fit with a bit of finagling,
   Cheers, MikeJ
Norniron:
Put up some pictures Mike!
Navigation
[0] Message Index
[*] Previous page
Go to full version
