Other Stuff > Interchangeability
Tank for a 350/4
royhall:
As the 400 was developed from the 350 you will find that a huge number of 400 parts will be a direct fit, others are just slightly changed. But if your building a special it wont matter.
For part numbers I bought both the 350 & 400 parts lists to compare numbers (Ashimoto will probably have PDF's of these on his list).
The front part of the frame where the tank locates is identical on both bikes (I am open to correction on that) so I would assume that any 400 tank will fit okay.
Personally I prefer the shape of the 350 tank for cafe's etc as the 400 can look a bit slabby (although there's been a black one on here this week that looks superb). Just a personal thing.
Let us know how you go on.
AshimotoK0:
Manuals here : http://www.sohc.co.uk/index.php/topic,8884.0.html
Think there is only the 400 parts manual though. But you can look here:
http://www.cmsnl.com/honda-cb350f-four-general-export_model14632/partslist/
Seat fit looks dodgy .
Orcade-Ian:
350/4 and 400/4 Tanks are definitely interchangeable (I've done it) as are side panels, top brackets identical but the lower fixings need swapping.
Ian
Bullit:
Splendid. Thanks chaps👍
That's makes it a little easier to find a decent one if mine can't be repaired.
Bodd:
I used a Kawasaki Z 550 LTD tank for my 400 cafe, I had to do a bit of tunnel beating/stretching to fit over the coils but nothing major, the overall dimensions (length/width) are almost identical.
Edit:- Forgot to mention I also had to move the fuel tap location.
Navigation
[0] Message Index
[*] Previous page
Go to full version
