SOHC.co.uk Forums > CB500/550
Fuel petcock repairable?
<< < (4/4)
AshimotoK0:
Will make you one soon ....if you still need one
Noelia:
--- Quote from: AshimotoK0 on September 30, 2015, 12:10:11 PM ---Will make you one soon ....if you still need one
--- End quote ---
Hi Ash! Yes please Im waiting for you :)
AshimotoK0:
--- Quote from: Noelia on September 30, 2015, 03:33:22 PM ---
--- End quote ---
--- End quote ---
Just found a bashed up CB750K7 tank languishing behind my shed  :-[ . Took the pertol  tap off it and it has a plastic reserve tube (original fitment)  that should fit perfectly. It tapers at the end where it goes into the alloy and should fit fine. Its from a 1977 tank.
Overall length 92mm, overall OD is about 5.8 but it tapers the last 15mm down to 5.35 mm wall is approx 0.7 ID is 4.3mm.
If you PM your address  can post it today.
CMS part description sounds like an apt description of Ronnie Pickering  ;D   .... and NO I don't know him!
cheers   ... Ash
Noelia:
--- Quote from: AshimotoK0 on October 01, 2015, 11:05:24 AM --- [ Guests cannot view attachments ]
--- End quote ---
--- End quote ---
cheers   ... Ash
--- End quote ---
Hi Ash,
The plastic reserve tube fits perfectly!
Thank you very much for your help!
Thanks!
JamesH:
Top man Ash....
Navigation
[0] Message Index
[*] Previous page
Go to full version
