CB750
Velocity stacks / Air filters
Topic: Velocity stacks / Air filters (Read 11931 times)
El__burro
SOHC Expert
October 15, 2015, 05:10:26 PM »
I reckon that the poor running (and even at idle) of the engine could be caused by the lack of air filters.
I have removed it and just kept the cones that look like velocity stacks.
Today I have covered them with a t shirt cutting and at times i felt like it improved the idling.
I don't want to reinstall the old filter box but I am not sure if this solution could work somehow.
Shall I opt for velocity stack or a set of these spongy filters?
El__burro
haynes66
Re: Velocity stacks / Air filters
October 15, 2015, 08:01:49 PM »
i think it looks fine as it is!!
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
mike the bike
CB400F, Royal Enfield Interceptor.
October 15, 2015, 08:58:22 PM »
Nothing wrong with T shirt filters, go for it.
Spitfire
October 16, 2015, 08:49:37 AM »
Now that is inventive, would never have thought of that one.
El__burro
SOHC Expert
October 16, 2015, 10:01:42 AM »
My mixture screw is all closed. How many turns should it be set to?
El__burro
October 16, 2015, 10:02:45 AM »
varies by exact model of bike and carb
El__burro
SOHC Expert
October 16, 2015, 10:04:36 AM »
It's a cb750 k2 with stock carb (no airbox). Surely all closed is not right is it?
Johnwebley
October 16, 2015, 10:33:42 AM »
my thoughts are tee shirt cloth is to restrictive,
I would experiment with tights,
maybe one or two layers,
not the thick woolly ones !!!!
see this link
http://www.speedwaybikes.com/handbook/sh_ch10.htm
October 16, 2015, 11:59:01 AM »
All closed is not correct, try about 2 1/8 turns out for a start
El__burro
SOHC Expert
October 16, 2015, 01:58:59 PM »
thanks,
that is a nice read.
Panty hose or nylon stocking is the way to go..
over the filter I mean.
Actually the screw that is all tight, is the throttle stop (according to the diagram) the one in copper visible in the picture.
I need to find the air mix screw and work out different settings.
thanks
el__burro
Last Edit: October 16, 2015, 02:07:16 PM by El__burro
Spitfire
Reply #10 on:
October 16, 2015, 03:28:01 PM »
These might help
El__burro
SOHC Expert
Reply #11 on:
October 16, 2015, 04:37:27 PM »
thanks Dennis,
actually the problem of poor idling is caused by fuel and not filter or air starvation.
when I feed the 2 sets of carbs individually it roars like a lion.
Probably there is a blockage in the connections between the carbs caused by the "rubbish" i found in the tank.
Is there an easy fix that doesn't require carbs removal?
el__burro
El__burro
SOHC Expert
Reply #12 on:
October 19, 2015, 03:05:52 PM »
I've removed the carbs just to figure out that there is no direct connection between 1-2 and 3-4.
My question is, how do I feed all the carbs at once.
I have one fuel pipe feeding 1-2 and the other 3-4
how this works exactly
thanks
el__burro
Spitfire
Reply #13 on:
October 19, 2015, 04:59:48 PM »
This shows the fuel lines on my CB750F1, hope it helps, here's a thread on the same subject.
http://forums.sohc4.net/index.php/topic,76367.0.html
Last Edit: October 19, 2015, 05:09:37 PM by Spitfire
El__burro
SOHC Expert
Reply #14 on:
October 19, 2015, 09:01:26 PM »
maybe I need to connect each fuel pipe to both carbs.
correct?
CB750
