SOHC.co.uk Forums > CB750
Velocity stacks / Air filters
<< < (6/6)
Chris400F:
No problem, it was worth a shot.
I have larger ones but they are a larger cross section than the one I sent so I think would be too thick.
I think any O-ring of a suitable material would do the job - it needs to fit inside the threaded portion where the bowl screws in so slightly larger than 26mm outside diameter.
Pity you didn't go for the bowl I came across and gave you the link for that came complete with a new seal, but that's the benefit of hindsight!.
El__burro:
problem solved (I hope for the long term)
I went down to my diy store (b&q) and I found a set of 6 plumbing O ring washer 3 different sizes two each @ £1.38
Fitted on the cup i am not sure if they are fuel resistant but since I fitted it I have no leak.
hopefully Ive managed to save at least a fiver.
Regards
el__burro
hairygit:
Here's hoping they are ethanol resistant, if they do fail, it'll leak that saved fiver faster than you can blink! Let us know if it's still okay in a month or so, if it works it'll be handy to know about easily available locally,as it always seems to be late on a Saturday things go wrong, with no bike shops open!
Sent from my X5 using Tapatalk
Chris400F:
How is your B&Q O ring lasting? Does it still seem to be resistant to fuel?
El__burro:
so far, so good.
Navigation
[0] Message Index
[*] Previous page
Go to full version
