Author Topic: Just bought this 750f  (Read 8520 times)
Offline pablo
« on: November 01, 2015, 10:44:05 AM »
Just bought this. Really want a k6 but this came up cheap and local.
Can anybody confirm exact model? It's on a s plate.
Also is colour genuine ?
« Last Edit: November 06, 2015, 05:03:38 PM by pablo »
Re: Joust bought this 750f
« Reply #1 on: November 01, 2015, 10:48:14 AM »
Looks to be a 750F2, comstar wheels and black engine being the main identifying features, although frame and engine numbers will give a definitive answer. Either way, colour is NOT original.
« Reply #2 on: November 01, 2015, 11:02:34 AM »
Plus one with Hairygit.
Its definitely an F2, alloy footrest hangers that only fit the F2 frame, Comstars, double disks, Awful Awful PD Carbs etc.
The exhaust is a non standard Motad (you wont find a NOS original anywhere, and when UKPete sells his I have first dibs). Motad is a good system though.
 Should be a 1977/78 if its an F2 so reg is correct.
The colour is not genuine but is a near match to the standard blue bike.
Not a bad looking bike though, think I would put the standard decals on the tank and clear coat it (if the paint is good enough).
Its also looks like it has a K series seat fitted, should have a tail hump on the F2. Loads of those available on eBay etc but you would have to match the paint.
Here's a comparison picture with mine.
Nice one.
« Last Edit: November 01, 2015, 11:46:28 AM by royhall »
« Reply #3 on: November 01, 2015, 11:43:45 AM »
Yep definately an F2
Online Bryanj
« Reply #4 on: November 01, 2015, 11:47:39 AM »
I concur at F2 and would add that exhaust valve guides wear out very quickly UNLESS they were replaced early with the very hard replacement parts
Offline pablo
« Reply #5 on: November 01, 2015, 01:35:09 PM »
Thanks for all the info. My mate and I bought it together cos it was cheap and local. £950
It's been off the road for 3 years  but my mate had it running pretty quick with fresh fuel and a new battery.
Now needs an mot and will just ride as is next spring to see if I like the 750s. I,ve  only ridden the 400 so far.
It's obviously had a new seat and lost the rear seat unit body work at some point?
Offline UK Pete
« Reply #6 on: November 01, 2015, 03:16:36 PM »
Yep as the others say its an F2, the best handling  , braking and fastest 750 sohc model, unfortunately the carb set up was never right, a nightmare to get them running good at tickover and lower revs, i have so many Nos parts for this model, i kinda had it in mind to do a real good restoration with the parts i have, but sadly it will make me more money to sell as parts,
pete
« Reply #7 on: November 01, 2015, 07:08:01 PM »
Stick the parts on ebay pete and make a shed load of cash...:-)
+1  ... to aid finishing your sandcast !
Offline pablo
« Reply #8 on: November 06, 2015, 04:56:46 PM »
Offline pablo
« Reply #9 on: November 06, 2015, 04:57:37 PM »
Offline pablo
« Reply #10 on: November 06, 2015, 04:58:46 PM »
Hi
The bike came with a motad on it 4:1.
The seller also gave me 4 of the pipes above. Can anybody identify it?
Pablo
Offline pablo
« Reply #11 on: November 06, 2015, 05:00:50 PM »
Started the deep clean today. Carbs and inbox off. Degrease and the best of a whole tube of autosol
Offline pablo
« Reply #12 on: November 06, 2015, 05:01:26 PM »
Offline pablo
Re: Just bought this 750f
« Reply #13 on: November 07, 2015, 10:35:55 AM »
No ideas on the pipes?
« Reply #14 on: November 07, 2015, 11:10:48 AM »
Google is brilliant at this.  From the numbers on the end of the silencer (063/44) and a bit of searching...
MIVV replacements for the DOHC CB750C
http://www.nbl.fi/~nbl3874/Vintages/CB750/CB750_EN.html
