Author Topic: Engine building guide/Loctite locations  (Read 12736 times)
Offline beemsquar
Re: Engine building guide/Loctite locations
« Reply #15 on: November 14, 2015, 02:18:51 PM »
Cheers Trigger, That's very kind,  I have nearly assembled everything now and am ready to seal the cases.
If you think it is better to use the graphogen I can wait for it to arrive.
I definitely don't want to do the job twice!
I'll PM you.
« Reply #16 on: November 14, 2015, 03:33:10 PM »
I would not bother as you have some assembly compound in place. Not worth a strip down.
Offline beemsquar
« Reply #17 on: November 14, 2015, 05:18:11 PM »
No problem, Thank you anyway. very kind of you!
Off topic but I don't suppose you could give me some advice on installing the piston rings?
I have a set of genuine Honda rings but am not totally sure which is the top and second ring.
One is slightly smaller than the other and one has a silver edge, which looks like there is a slight chamfer maybe. Im guessing this is the second ring as the Clymer manual states?
The other is a tad bigger and is completely black, Top ring? Both have a tiny N on one side which I am also guessing must be the top?
Both seem the same thickness to me, but I'm not sure.
Any help would be appreciated!!
Online ST1100
« Reply #18 on: November 14, 2015, 05:29:08 PM »
I use Graphogen, much better to match new shells when running in.
Out of interest: would Down Corning Molykote G-N Paste serve too?
STOC #637
Offline Chris400F
« Reply #19 on: November 14, 2015, 06:11:11 PM »
Haynes manual states that the stamped letter indicates the top of the ring.
Also has this diagram showing the ring layout:
« Reply #20 on: November 14, 2015, 06:43:28 PM »
The top ring (compression ring) will have the silver edge. The second ring (scraper ring) will be black.
Offline beemsquar
« Reply #21 on: November 15, 2015, 10:49:00 AM »
Cheers guys, I figured it out in the end, really hard to see any noticeable difference in the shape of the two at first, but I got there eventually. Strange my Haynes manual doesn't have that image, the clymer did. But it was slightly different.
