SOHC.co.uk Forums > CB750
phil read replica conversion
<< < (2/2)
royhall:
Hi John. Nice to see you back on the forum again.
Don't know if its any relevance to what your doing, but I am looking at fitting early CB600 front and rear to an F2.
Have got the bits, and it looks from the tape like a reasonably easy swap. Trying to keep it all Honda.
Do you remember me coming up and buying the F2 frame from you summer before last. Have a look at what KNE599V looks like now.
http://www.sohc.co.uk/index.php/topic,8188.msg53822.html#msg53822
Cheers Roy.
whiteylfc:
Hi Roy....good to hear from you and see what you did to KNE......Everything that was on that bike I put onto a T plate frame that I'm now putting the modifications on.I only started it because I was told it was easy to do................. ITS NOT.....!!but as they say on Mastermind.....I've started so i'll finish....
royhall:
Good luck with it John. Keep us posted with some piccies. Cheers.
whiteylfc:
hi roy...a couple of new photos to show you of todays work.i wanted to temporarily fit all the fzr front end to see what will need altering.although the forks are much wider,the fairing hardly needs any shaving.the fzr's clip on bars are in exactly the right position which will save loads of time and expense......
whiteylfc:
the fzr swinging arm is fitted and I've had alloy lugs welded on to take the bottom of the rear shocks.i've put a 17 tooth K5 front sprocket for a 530 chain to match the fzr rear sprocket.
does anyone know if anyone supplies new rear brake cylinders?the two I have are completely seized and possibly beyond rebuilding.
Navigation
[0] Message Index
[*] Previous page
Go to full version
