Author Topic: 1977 CB550  (Read 65617 times)
Offline Valentinik
Re: 1977 CB550
« Reply #90 on: July 15, 2016, 09:30:21 PM »
Thanks trigger, I've got some blue hylomar so will go with that if it's suitable.
Mike
Re: 1977 CB550
« Reply #91 on: July 16, 2016, 01:06:43 AM »
Don't forget to put the primary gear inside the chain first
Offline Valentinik
Re: 1977 CB550
« Reply #92 on: July 16, 2016, 03:03:08 PM »
Thanks for the pointers both, the kickstart is already assembled in the bottom case. I have however forgotten to order the cap for the clutch shaft.
The local main dealer can't get them in stock and they are a week special order from DS so il have to wait for it to arrive before I can assemble the cases.  >:(
Offline Valentinik
Re: 1977 CB550
« Reply #93 on: July 30, 2016, 10:39:49 PM »
My oil seal arrived today so I got on with building the engine cases back up.
I got both cases mounted together and the primary installed:
I have also installed the gear shift:
A concern I have though is, there seem to be 2 small issues with the casting either side of the shaft, shown in this picture. Is this something I need to be concerned about?
Mike
Re: 1977 CB550
« Reply #94 on: July 31, 2016, 06:57:07 AM »
I seem to remember that the line on the bearing should be horizontal with the joint line so are you sure it was on the locating peg properly?
Offline Valentinik
Re: 1977 CB550
« Reply #95 on: July 31, 2016, 10:07:02 AM »
Thanks Bryan, I did look at that and double checked the pin was located and that everything moves as it should. I've also got a picture of it like this before I stripped it down:
Mike
Offline Valentinik
Re: 1977 CB550
« Reply #96 on: August 09, 2016, 09:49:45 PM »
Thanks oddjob.
Over the weekend I got the engine bits painted and baked in my home made oven.
« Last Edit: August 09, 2016, 09:53:09 PM by Valentinik »
Offline Valentinik
Re: 1977 CB550
« Reply #97 on: August 09, 2016, 09:51:57 PM »
I also collected the remainder of the parts from powdercoat
I've also ordered the tyres for the wheels so hopefully will drop the wheels off to be built with new spokes at the weekend.
Offline Valentinik
Re: 1977 CB550
« Reply #98 on: August 10, 2016, 09:15:12 PM »
Thanks, I think I did like the look of the bolt head being the same colour as the case in this instance. For the less (torque) critical bolts I was planning on using stainless cap heads where I can. (Covers,engine mounts,etc).
You are correct, the gear shaft seal was missing when I took the picture but it's been installed now. Along with fitting the Pistons to the rods.
Offline Valentinik
Re: 1977 CB550
« Reply #99 on: August 10, 2016, 09:21:28 PM »
I took the tank to a friend today who is the paint shop manager for a very large dustbin lorry manufacturer as he offered to paint the tank for me.
I try to do as much of the work myself and to learn new skills as I go. However, the equipment he's got to use will undoubtedly give a better result than me doing the job myself.
The colour I've chosen may not be to everyone's taste but I'm hoping it will suit the style I'm going for.
Offline Valentinik
Re: 1977 CB550
« Reply #100 on: August 11, 2016, 09:28:48 PM »
The tyres and new wheel bearing arrived today. I got on with pressing the bearings in so I can take the wheels to be built up at the weekend.
Offline yozzer74
Re: 1977 CB550
« Reply #101 on: August 12, 2016, 06:25:30 PM »
It's looking good what colour spokes you going for
Offline Valentinik
Re: 1977 CB550
« Reply #102 on: August 12, 2016, 06:27:49 PM »
Thanks, the spokes will be satin black also.
It's probably a bit too much black for some tastes but I've never really been a fan of shiny things like chrome, stainless etc. So I'm trying to limit the amount used to bolt heads etc.
Mike
Offline MarkCR750
Re: 1977 CB550
« Reply #103 on: August 12, 2016, 10:36:56 PM »
I have black rims/spokes on my mountain bike, but with red anodised nipples, looks mint, just a thought!.
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Offline Valentinik
Re: 1977 CB550
« Reply #104 on: August 13, 2016, 10:28:55 PM »
Thanks mark, the only other colour I'd have gone for was to match the tank but I don't think the colour I've chosen is available.
