SOHC.co.uk Forums > Project Board
1982 Nighthawk Restoration ( attempt )
<< < (5/5)
Chris400F:
--- Quote from: Krzychu on April 04, 2016, 03:40:31 PM ---Thanks Chris  :) PM sent  ;)
--- End quote ---
Replied when PM received, did it get through? There seemed to have been a few problems with PMs last week.
Resent to be on the safe side.
Krzychu:
Indicators came in today Chris, great job they are. Thanks again
LwG
Krzychu:
Hi all, just another little update on what is going on in here - not much to be honest.
Indicator from Chris on the bike, replaced one that was squashed at the back.
I have changed exhaust studs around as some were damaged, I got a set of ebay that are m8 into m6. As some threads were damaged in the cylinders, I have re-threaded them into m8 and left the m6 on the outside. No pics of that operation but  :(
And just yesterday fitted new drive as the old one was well overdue. I went for a gold DID 530vx and JT sprockets.
Issues to be looked at now are : there is a rattle from inside the clutch cover, if You remove the oil stick You can here it very clearly - sounds like the was a loose nut flying around ?? ( there is not )
Next one but  think not as serious ( ? ) is back fire on cylinder 1 or 1 and 2. When test riding if You go into higher revs and then let go it would back fire  :(
Any ideas ??
totty:
"When test riding if You go into higher revs and then let go it would back fire"
Missing or blowing exhaust gasket can cause this.
Krzychu:
Hi Totty, if You mean the  " copper ring " exhaust gasket then they are all there and all new
LwG
Navigation
[0] Message Index
[*] Previous page
Go to full version
