Author Topic: Tapered steering head bearing install  (Read 6878 times)
Offline sam_vfr
« on: February 26, 2016, 03:00:28 PM »
Right then.  I'm in the process of rebuilding my cb550 and I'm just about ready to install the head bearings.  I have a set of bearing from All bearings and they come with 2 different thickness spacers.  I've read so many post of what thickness to use and where to install the spaces that I'm still none the wiser.  Unfortunately I don't have the old races that I can measure and compare.  Is there another way of measuring this prior to fitting to make sure I use the correct spacer?
The last thing I want to do is fit one spacer then find out its the incorrect one and have to take it off!!
Pic below if your interested!
Offline JustcallmeMrT
Re: Tapered steering head bearing install
« Reply #1 on: February 26, 2016, 07:48:13 PM »
I just went through the exact same process.  I read a bunch of posts and the consensus was to use the thin washer, so that's what I did and it fit perfectly.  Hope yours works out as well!
Offline sam_vfr
« Reply #2 on: February 29, 2016, 01:02:43 PM »
Thanks MrT
Did you use the thin washer underneath the bearing on the tripple tree or inside the headset?
Sam
« Reply #3 on: February 29, 2016, 05:30:47 PM »
And the washer keeps some of the shite out of the bearing.
Offline sam_vfr
« Reply #4 on: March 01, 2016, 04:15:46 PM »
So would I be correct in saying the washer goes on first, then the dust seal, then the bearing?
Sam
Offline sam_vfr
« Reply #5 on: March 02, 2016, 09:52:57 AM »
All done now.  Thanks for your help.
Only thing that I may need to do is use a slightly thinner washer under the top yoke nut as there does not seem to be much thread there!
