Author Topic: New Honda cb550f in the family but... Engine rattle!!  (Read 16802 times)
Offline Noelia
« on: March 16, 2016, 07:45:07 PM »
Hi all!
After almost a year since I bought my cb500 and which I haven't ride yet due to some silly issues (paperwork and clutch being hard rock) I've got a message from my Spanish friend from Liverpool saying that finally one of his work colleagues decided to sell his bike. I was going to buy this one before I bought the 500 but he changed his mind. However it was a great surprise and I rapidly say I will buy it!
The bike is not 100% original but it looks great and had the engine rebuild plus other upgrades like electronic ignition etc etc...
The bike arrived today! And I was so excited! It looked so good!
I fire up the beast and then.. There it is that infernal noise coming out of my brand new old toy... So disappointing...
I think it is the cam chain needing adjusting?
What do you think?
Also a few pictures of the new baby.
... Would I be able ride some day??
Noelia
Offline Noelia
« Reply #1 on: March 16, 2016, 07:48:08 PM »
I Can't see the video but the link is there... Can someone confirm?
Noelia
Offline MCTID
Re: New Honda cb550f in the family but... Engine rattle!!
« Reply #2 on: March 16, 2016, 07:49:27 PM »
It looks OK to me Noella.
Offline matthewmosse
« Reply #3 on: March 16, 2016, 08:07:31 PM »
Not 100% sure but sounded ok when reved? I belive clutch baskets rattle a bit sometimes, also out of balance carbs might be a culprit or contributer.... Over to the experts.
« Reply #4 on: March 16, 2016, 08:35:35 PM »
it doesn't sound to bad,
  suggest you check the tappets,cam chain tension,and plugs,
 when the plugs are out,it will give you some idea of mixture,
   any nasty smoke when revved?
  just needs some TLC
Offline Noelia
« Reply #5 on: March 16, 2016, 08:41:46 PM »
  just needs some TLC
Hi John,
No smoke at all.. Very clean... It fired up straight away, the last owner is horrified he said he rode it last weekend and there was no noise...
I'm not sure on how to check the tappets but  i reckon it is all related.
Noelia
Offline dave400
« Reply #6 on: March 16, 2016, 08:44:23 PM »
It runs so take it for a ride, get it revved up bring it home do a full service adjust everything that's making a noise.....then enjoy the beast its old and they do rattle more than modern bikes engines..".cheers
« Reply #7 on: March 16, 2016, 08:56:52 PM »
  just needs some TLC
Hi John,
Noelia
  they are simple to work on,I suggest you check Ashimoto dropbox for a manual,or get a Haynes,
  just read,and understand,you can get lots of help here
  watch this
https://www.youtube.com/watch?v=bLw6Av07wik
it will give the basic idea
Offline Noelia
« Reply #8 on: March 16, 2016, 09:09:59 PM »
  just needs some TLC
Hi John,
Noelia
  watch this
I need a feeler gauge but thank you so much!! I'm not too confident on this, but I will try to get one of those feeler gauge and try it!
Noelia
« Last Edit: March 16, 2016, 09:15:12 PM by Noelia »
« Reply #9 on: March 16, 2016, 09:29:13 PM »
take the tank off,
  and take your time,
  carefull removing the 8 caps,a good socket is needed,
« Reply #10 on: March 17, 2016, 07:46:48 AM »
Use a 6 sided 17mm socket, not one of those 12 sided ones.  Put some paper over the tappet cover first.  That way you'll avoid the corners being chewed up.
Just follow the manual, take your time and you should be OK.
Offline Noelia
« Reply #11 on: March 17, 2016, 01:24:55 PM »
I will put my hands on it this weekend, hopefully I will be able to fix it without having to take to the garage....
Noelia
« Reply #12 on: March 17, 2016, 07:55:02 PM »
If the thing ran perfectly for the last owner last week, then plug caps would be my first port of call, just tighten them on a turn and / or wd40 sprayed up inside the cap - for some reason I had a spate of plug caps fail across 3 differnt bikes in the last 4 years, none previously to that, wd40 seemed to revive them briefly - enough to get home / keep commuting a few weeks. It cannot hurt to do a full service for peace of mind in any case.
Offline Noelia
« Reply #13 on: March 18, 2016, 07:24:54 AM »
I haven't thought about that I will check the plugs tonight.
Thanks!!!
Noelia
Offline Noelia
« Reply #14 on: March 24, 2016, 03:12:52 PM »
Picked up the 550 yesterday from the garage but the engine is  still rattling... Carbs have been balanced, valves and cam chain adjusted.
The mechanic said I need to have a long ride for it to settle and go away, does anyone experienced something like this before?
Noelia
