SOHC.co.uk Forums > CB750
CB750 electrics
Spitfire:
I had a similar problem on my F1, it all looked fine until I looked at the back of the fuse box which was corroded to hell, I replaced it and have not looked back since. Hope yours is as easy to fix.
adriangsmith:
Thanks all,
A bad earth sounds the most likely issue.
I also will check the condition of the rectifier.
Also what is the small plug in aluminium block located by the indicator relay? some sort of safety diode??
I'll check when i get home tonight.
Fuse box is in good condition.
adriangsmith:
Bad earth was the cause. All sorted now :) thanks all!
diabolics:
As they say. Classic bikes have 3 types of electrical problems. Bad earths, Bad earths and Bad earths
mike the bike:
Another gardening mystery solved; bad earth
Navigation
[0] Message Index
[*] Previous page
Go to full version
