Author Topic: Rounded head  (Read 9322 times)
Offline Carb17
Rounded head
« on: April 05, 2016, 07:55:48 PM »
Hi guys , I've hit my first hurdle which I'm sure will not be my last , when trying to remove the front wheel I tried to unscrew the speedometer which already had a slightly rounded head and made it worse . Any tips on how to remove the screw and also where I could get a new one would be great thank you
Offline Chris400F
Re: Rounded head
« Reply #1 on: April 05, 2016, 08:18:44 PM »
Have you tried an impact driver? A really useful part of any toolkit when dismantling bikes.
Offline Krzychu
Re: Rounded head
« Reply #2 on: April 05, 2016, 08:29:44 PM »
Hi there, You can look up on flebay for bolt removing kit. They are not all that expensive and You have a good chance You will need to use it few more times in the future 😉
LwG
LwG✋
Offline haynes66
Re: Rounded head
« Reply #3 on: April 05, 2016, 08:56:53 PM »
ive used either a small chisel or a screwdriver to remove these. persistent tapping rather than a good wallop. place your chisel as close to the edge as possible and work your way round.
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
Offline RGP750
Re: Rounded head
« Reply #4 on: April 05, 2016, 09:11:53 PM »
Drill a small hole in the center of the cross about 8mm deep and
get a good  quality torx bit slightly larger than the hole tap it in and undo with a
small socket.
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline Carb17
Re: Rounded head
« Reply #5 on: April 05, 2016, 09:21:06 PM »
Thanks for everyone's advise will attack it again in the morning
Offline Carb17
Re: Rounded head
« Reply #6 on: April 05, 2016, 09:33:35 PM »
Can anyone recommend the best place for spare parts? I.e a new screw that I rounded off on the speedometer attached to the wheel , thanks
Re: Rounded head
« Reply #7 on: April 05, 2016, 09:40:48 PM »
A good old fashioned hardware shop is always a good bet. Sadly House of Hastings (used to be thorcraft) has gone, and I think even Mozeley's in Castle street has gone now. A seller on e bay called "massive attack" has a wide range of nuts bolts etc, in bzp or stainless, he does any amount, and his postage is very good.
Re: Rounded head
« Reply #8 on: April 05, 2016, 10:55:02 PM »
if I remember that screw is the same as one that holds the tacho cable,
 slight domed with a countersunk head,
 http://www.cmsnl.com/honda-cb500-four-k1-england_model14660/93700-050160a-screw-cross_93700050150a/#.VwQ0C6QrLIU
check this
Offline Carb17
Re: Rounded head
« Reply #9 on: April 05, 2016, 11:00:11 PM »
Yep thats the one
Re: Rounded head
« Reply #10 on: April 05, 2016, 11:01:03 PM »
small socket.
+1 on Rich's method  :) ... I do that all the time. Or Mig weld a blob of weld onto the head and then file a couple of flats onto the blob and use Mole grips to remove it while everything is still hot. Remove the plating first though
Re: Rounded head
« Reply #11 on: April 06, 2016, 08:15:05 AM »
However you do it do not hit too hard or you will break the speedo drive, even more so if you are undoing thr tacho one
Offline masonmart
Re: Rounded head
« Reply #12 on: April 06, 2016, 09:43:04 AM »
I had the same problem with every phillips head screw on the bike. In the end I removed every screw with an impact driver, they're invaluable. Also get a set of drivers with a metal hexagon at the end opposite the blade. These you can impact the screw with to break the galling and get a lot more torque on with a spanner or socket.
Dresda CB500-4, 605 cc
CB-77, 350 cc
1968 Bonneville
1976 Thruxton Velocette
1974 Kawasaki Avenger
1997 VFR 750
Re: Rounded head
« Reply #13 on: April 06, 2016, 11:03:45 AM »
Therein lies the problem, they're not Phillips screws, they're JIS! Using a Phillips driver will cause it to 'cam out' and slip if any serious torque is applied.
This page explains, with a diagram.
http://www.vesseltools.com/hand-tools/screwdrivers/jis-japanese-industrial-standard/view-all-products.html
After taking all the allen screws out of my bike and going back to the OEM silver chocolate ones, buying JIS screwdrivers was essential, I found a reasonably priced pair on eBay.
Offline masonmart
Re: Rounded head
« Reply #14 on: April 06, 2016, 12:11:19 PM »
Yes understood but I call them all Phillips screws. I had the right bits for the impact drivers and screw drivers so rounding wasn't a problem only getting enough torque on them to move them. My bike and engine were seriously corroded though.
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
