SOHC.co.uk Forums => CB750 => Topic started by: Sgt.Pinback on May 07, 2016, 07:06:48 PM
Title: (CB750 and others) Master brake cylinder overhaul
Post by: Sgt.Pinback on May 07, 2016, 07:06:48 PM
Will have to overhaul my KO master brake cylinder. Boot is toast.
In order to get out the clip of the master brake piston HONDA says grip 07073-30001.
Where to get one or what tool do you use?
Title: Re: (CB750 and others) Master brake cylinder overhaul
Post by: Liam on May 07, 2016, 08:42:04 PM
Something like this I think…
https://www.koolairconsupplies.com/trident-t244100-snap-ring-pliers.html
Or try an ebay search for long nosed circlip pliers...
Post by: Green1 on May 07, 2016, 09:18:13 PM
I found I had to grind down the pliers in your link to reach the clip
I have since found it easier to remove the clip with a small pick or screwdriver
Mick
Post by: Chris400F on May 08, 2016, 09:34:17 AM
I managed to remove the circlip when I did the MC on my 400 with a pair of these:
http://www.ebay.co.uk/itm/6-INTERNAL-STRAIGHT-NOSE-CIRCLIP-CERCLIP-OIL-SEAL-SNAP-RING-PLIERS-PLIER-w5900-/262001868719?hash=item3d00873faf:g:7VkAAOSwLVZVyzfH
Post by: Bryanj on May 08, 2016, 11:05:09 AM
If the seals are OK and its just the boot you only need to get out a wire coirclip that is not in a groove
