SOHC.co.uk Forums => CB500/550 => Topic started by: Beddgelert on May 10, 2016, 07:57:59 PM
Title: Hondabond or not?
Post by: Beddgelert on May 10, 2016, 07:57:59 PM
I am starting to put my top end back together on my 550 and wondered if I should put some liquid gasket (hondabond etc) on along with the new gaskets?
It makes sense but I am just concerned that it will be a pig to separate them again in the future?
Title: Re: Hondabond or not?
Post by: Trigger on May 10, 2016, 08:05:57 PM
NOOOOooooooooooooo, if the gaskets are a good make (NP or Vesrah) everything should be good.
Post by: Green1 on May 10, 2016, 10:57:43 PM
It won't be a pig to pull apart but if you use it you will be pulling it apart agian in the near future
Post by: JustcallmeMrT on May 11, 2016, 07:05:44 AM
I used plain vesrah gaskets as per Triggers advice and all is well - no leaks!
Sent from my SM-N9005 using Tapatalk
Post by: Bryanj on May 11, 2016, 07:40:39 AM
Honda bond is ONLY for the metal to metal surfaces never on gaskets and don't even think of the silicone word
Post by: Beddgelert on May 11, 2016, 03:04:29 PM
Thanks for the advice guys,  I have some vesrah gaskets so all should be well.
What do they say about a little knowledge........!
