Other Stuff => Misc / Open => Topic started by: 3scs on May 13, 2016, 07:12:56 PM
Title: rear brake drum repair
Post by: 3scs on May 13, 2016, 07:12:56 PM
hi just wondering has anyone done the rear brake drum repair would you recomend using any loctite if so which one would be best to use
Title: Re: rear brake drum repair
Post by: Bryanj on May 13, 2016, 07:15:21 PM
Which rear drum are you talking about?
Post by: 3scs on May 13, 2016, 07:18:35 PM
sorry its cb 550 k3
Post by: Bryanj on May 13, 2016, 07:21:32 PM
Need to be shrunk in not loctighted
Post by: 3scs on May 13, 2016, 07:29:19 PM
wasnt sure wether to loctite also thanks
Post by: matthewmosse on May 13, 2016, 08:25:34 PM
When I did mine I froze the insert, and heated the hub using acetalene whilst it was spinning on the lathe, then used the tailstock to push the two together, on a spare wheel I have that was re lined by someone else they also drilled 3 points along the joint and tapped then inserted grub screws so they were half the diameter into hub and half into liner. I would immagine that required a very stable drilling platform for the drill to go square and not veer off into the soft alloy. Personally I was happy to use the tight fit and heat expansion by themselfs and save a tricky bit of work.
