SOHC.co.uk Forums => CB500/550 => Topic started by: masonmart on May 25, 2016, 01:21:08 PM
Title: Electronic ignition
Post by: masonmart on May 25, 2016, 01:21:08 PM
Can anybody recommend a good EI system for a CB500.
MM
Title: Re: Electronic ignition
Post by: royhall on May 25, 2016, 02:14:37 PM
Boyer Bransden every time. Bit of a faff to fit but well worth it. Avoid the cheaper ones as you'll end up at the side of the road scratching your head.
Post by: JustcallmeMrT on May 25, 2016, 02:22:40 PM
I installed a dyna system and accidentally fried it by leaving the key on for awhile before starting the bike - apparently if you don't start the bike the unit wont discharge and nasty things happen - there is a risk if on for any more than 10 seconds... really wish they would have said that in the manual....
Sent from my SM-N9005 using Tapatalk
Post by: masonmart on May 25, 2016, 03:00:05 PM
How about the Units that David Silver sells at around £100?
Post by: Trigger on May 25, 2016, 03:07:48 PM
I know Norniron got one from DSS and said it was shite.
Post by: deltarider on May 25, 2016, 03:21:12 PM
Quote
Could you be a bit more specific? Cheaper ones of Boyer & Bransden you mean?
Post by: royhall on May 25, 2016, 04:43:28 PM
Sorry I should have said, stick with Boyer and avoid the cheapies like the dss unit or the other eBay offerings. You only want to do this once so pay a bit more for the Boyer unit. There's people on here that fitted Boyer 30 plus years ago and never touched it since. Highly recommended.
Post by: deltarider on May 25, 2016, 06:01:44 PM
Quote
Could you be a bit more specific? Now your comment has much of the 'Now that I've spent all that money, it must be good bias'. What other eBay offerings do you have experience with?
Heck, I've built my own (for less than € 18,-) and it has worked perfectly for 15 years till I tore some wires myself by mistake. I'll repair it soon as all components are still OK. There's nothing special about EI. If you look closely at a contactbreaker it must be more expensive to manufacture  than an EI.
Post by: royhall on May 25, 2016, 06:14:04 PM
Quote
Heck, I've built my own (for less than € 20,-) and it has worked perfectly.
Not correct DeltaRider, I don't care what it costs. Boyer has a reputation in the EI game second to non. This is a topic that has been aired again and again on this forum and on the internet generally and the opinion is usually buy Boyer. The online forums are littered with tales of DynaS failures. Already on this short thread Dyna and the DSS systems have been slated. Just trying to help a forum member as not everyone is capable of building there own.
On a more positive note. The Boyer system not only does away with the points, but the mechanical advancer as well. Thus becoming totally electronic. I have it fitted to two of my bikes, and would definitely recommend them. But Deltarider is absolutely correct in that it is an expensive system especially if you use the matched mini coils as I have done.
Hope some of this has assisted you Masonmart.
Post by: masonmart on May 25, 2016, 08:06:48 PM
To say that the DSS units are crap is a bit of a sweeping statement without saying why. I guess that the main reason is that they use the existing advance and retard?
Just another question. How much improvement does EI make over points? For an engine that hasn't run for 40 years and has just been rebuilt may it be better running it initially on points?
Post by: Norniron on May 25, 2016, 10:14:22 PM
It was indeed Pure SHITE Graham
Post by: Norniron on May 25, 2016, 10:21:01 PM
Doesnt Hondaman on sohc.net do a electronic ignition for the 500/550 that incorporates the original points?
Post by: Johnwebley on May 25, 2016, 10:23:55 PM
 I have used Boyer since about 1978 ish,
  can't say better than that,
expensive ???   it cost me less then £30,
 it may have gone up since then,but I am very happy with it
Post by: Trigger on May 25, 2016, 10:31:42 PM
Why don't you say it as it is David ;D ;D
Post by: royhall on May 26, 2016, 06:55:14 AM
Have a look at this link:
http://www.sohc.co.uk/index.php/topic,9489.msg66492.html#msg66492 (http://www.sohc.co.uk/index.php/topic,9489.msg66492.html#msg66492)
Boyer don't actually list a system on their website for the CB500 so unless the 400/750 system fits it may be ruled out. Someone will know?
Cant think of another system other than Boyer that does away with the mechanical advancer.
Post by: deltarider on May 26, 2016, 07:37:43 AM
Quote
Yes and so does mine. Let's call his and mine a transistor ignition module to destinguish it from a full electronic unit. An advantage over the fancy expensive stuff is that, if anything goes wrong, the old situation can be restored within minutes. Mine has worked reliably for over 60.000kms with the same contactbreakers. I also like where my module is located, in a box attached to the battery (see pic) and not in a hot (condense) and vibrating place. If you make your own, make sure to use supple wire. My wires got hard and one came loose (after 15 years) when I removed the battery for winter storage. BTW, I advice first to have your project running with the oldstyle ignition before you throw money at it and then, when you're satisfied with the bike, you can consider going electronic which has some advantages like a better idle and somewhat more response in the high rpms. But do not expect even one HP more.
Post by: AshimotoK0 on May 26, 2016, 08:08:39 AM
Quote
I  too made designed my own but back in 1980. It was an 400v inverter CDI type as used on early Kwak triples but I still used the points as it was then literally a 5 minute swap over to standard if necessary (not that I ever needed to)  . Contrary to all of what you hear I never had to  re-time it or adjust / change  the points in 20k miles, all I did was lubricate the felt on the points plate regularly. I just passed a few milliamps through the points to 'electrically' clean the contacts. Redesigning it with modern parts (Capacitor was originally from a Pye Valve Colour TV, today I would probably use one from a microwave, although a little bulky.) but its a project that always seems to be 'on the back burner'  :-[ :-[) . This was on my 1st 400/4 and lived where the tool tray sits, it was still on it when I sold it. It retained the standard coils and you could get a whopping great spark from it.
Post by: ginger_jim on May 26, 2016, 10:45:03 AM
I guess electronic ignition units are only as good as the loom/charging system.  Cant see the problem with using the existing advance and retard unit as long as it is in good condition, particularly the springs.  I fitted a DS unit and haven't had any issues; I felt it was re-assuring to eliminate timing issues when setting the bike up.
Post by: deltarider on May 26, 2016, 11:37:10 AM
Quote
+1. I remember that even with the old stock(!) ignition set up I returned from a 10.000km journey (France, Italy, Greece) and still did not need to adjust anything.
Post by: totty on May 26, 2016, 06:53:58 PM
Depends on your starting point, with genuine points, plate, coils etc. I'd try it first. If low quality after market bits are fitted I'd just go electronic as there isn't much price difference to a full set of original parts.
My 550 had a flat spot that I couldn't shift without replacing the advancer so I went Boyer.
Post by: masonmart on June 08, 2016, 04:39:13 PM
I'm probably going to buy Boyer or should I say Micro-Digital, these are recently priced and don't use the existing advance unit.
They need to use Micro Digital coils if the impedance of the existing coils isn't OK. Can anybody confirm if the existing CB500 K1 coils are OK in this respect
Post by: Laverda Dave on June 08, 2016, 06:00:39 PM
I fitted a Boyer to my 400/4 in 1992, its still in there going strong and I have never had to do anything to it once it was set. Ill be fitting another one to my project 400/4 no question.
Post by: gtmdriver on June 08, 2016, 06:13:26 PM
As far as I know, and I'm open to correction, the same unit fits all the early inline 4's. I'm using the Boyer unit on my CB350F.
Interestingly the Boyer system fires all 4 plugs together.
You also need to make sure the ignition coils have a primary resistance of at least 4 ohms.
Post by: masonmart on June 08, 2016, 07:03:44 PM
The spec sheet shows a lowest primary resistance of >5 ohms
Post by: royhall on June 08, 2016, 09:49:45 PM
They will physically fit all the 4's but the advance curve is not the same on them all. I have one on my 350F that was made for the 400/4 that has a different advance. I was told it would move the full advance a further 1000rpm up the scale, but it still works really well. May not be too important.
Post by: deltarider on June 08, 2016, 10:12:52 PM
Quote
Strange, are you sure?
Post by: masonmart on June 09, 2016, 08:26:44 PM
Quote
Just from the manual that I have but I'll check. I measured my coils today and the primary resistance is <5 ohms. I'll buy the Micro Digital coils just in case. £100 is worth it insurance wise.
Post by: deltarider on June 09, 2016, 08:54:36 PM
Why the hurry. I'd rather expect B&B ment < 5 Ω because for example OEM Honda coils measure 4,7 Ω.
Post by: gtmdriver on June 10, 2016, 04:34:01 PM
This is a copy of the original instructions.
(http://i41.photobucket.com/albums/e254/gtmdriver/Boyer%20Bransden%20Instructions%201_zps1inda4ag.jpg) (http://s41.photobucket.com/user/gtmdriver/media/Boyer%20Bransden%20Instructions%201_zps1inda4ag.jpg.html)
and this is the reply I got after enquiring about suitability for the 350/4
"Hi. Could you tell me whether the KIT00089 designed for the Honda 400/4 will also fit the very similar CB350F 350/4 which was its contemporary everywhere but the UK?
Hi, If it fires the same (has the same degrees for firing) and is also a single cam, then yes it should be fine. Regards Stuart
As standard it has two contact breakers set 180o apart with a single cam running at crankshaft speed. It uses the wasted spark system to fire two cylinders together.
I guess the only unknown is whether the ignition advance curve built into your system will also suit the 350.
I have found these figures in a genuine Honda service manual.
Honda CB350F centrifugal ignition advance
Start of ignition advance 1400 – 1600 rpm
Full advance reached 2300 – 2500 rpm
Advance angle 23.5o – 26.5o
Are these anything like the advance curve built into the KIT00089 electronic replacement?
Hi John, It sounds like it should be ok. The total advance should cover the 350.The system will run standard 4 ohm dual coils and will need 5k ohms plug caps, should already be on the machine.
t looks like the start of advance is ok, and the system will cover the fully advance figure. Our system reaches fully advance at around 3,500 rpm."
When I found that the DSS replacement coils were only 2 ohm I phoned BB and they told me I would need to run with ballast resistors.
...and this is how I fitted them.
(http://i41.photobucket.com/albums/e254/gtmdriver/DSC00012_zpsv6myfvuy.jpg) (http://s41.photobucket.com/user/gtmdriver/media/DSC00012_zpsv6myfvuy.jpg.html)
This is the wiring diagram without ballast resistors.
(http://i41.photobucket.com/albums/e254/gtmdriver/Boyer%20Bransden%20Instructions%201_zpsahpgp6fq.jpg) (http://s41.photobucket.com/user/gtmdriver/media/Boyer%20Bransden%20Instructions%201_zpsahpgp6fq.jpg.html)
Post by: cb550k-aaron on July 25, 2016, 11:03:42 AM
I Have one of the Boyer Bransden Mk3 kit but when it's all linked up it's only drawing 1v :( anyone any ideas?
Post by: Ashdowner on July 26, 2016, 08:21:07 AM
I've had 2 CB550K3's - 25 years apart. the first one had Boyer ignition and it went like a dream with absolutely no problems. The one I have now has a DSS unit in it and it also goes like a dream - BUT......since I installed it my battery discharges if I have my headlight on. I know the Boyer system draws 1.5 amps (e-mail this morning) and I'm waiting for DSS reply to tell me how much theirs draws. If it's the same then it's obviously a charging/battery problem. The bottom line though is that in terms of performance I believe the units to be equal.
Post by: masonmart on July 30, 2016, 09:57:31 PM
I bought a Boyer unit in the end. It is all electronic
Post by: Johnwebley on July 30, 2016, 11:55:09 PM
  I run Boyer ignition,and  H4 halogen  headlight,
 normal open road riding its works great,but if your stuck in town traffic for long,it can cause an issue,
Post by: Ashdowner on August 06, 2016, 10:01:41 PM
I have the same problem. I've made a difference though simply by putting an LED stop/tail in. I'm also going to get LED's into the indicators (ok not a great win per £ spent) but if I'm in traffic mine suffers as well and the indicators don't help. Also going to get an LED headlight bulb which would make the biggest difference but I'm struggling to understand which one is best.
Post by: ST1100 on August 07, 2016, 01:55:45 PM
You'd need to check if the Evitek G6 H4 (with shield!) would be avail for LHS traffic...
Dunno if the heat-sink/fan assy will fit the headlight bowl though...
