SOHC.co.uk Forums => CB750 => Topic started by: MarkCR750 on July 05, 2016, 10:31:38 AM
Has anybody found a cheaper alternative to David Silvers price if a fiver each?, mine could do with replacing and including the ones for the air filters it gets a bit expensive!
Hi Mark
is this any good.....http://4into1.com/black-carburetor-clamp-47mm-50mm-set-of-4/
http://4into1.com/air-box/
Greebo
PS... what about the Assen GP & Rossie... we thought it had finished, but had another 12 lap re run... :o
Cheers Greebo, and yes, I saw the highlights, was about to switch off and it restarted!, still no good for Rossi though 😒
I think Rossi has a hell of a fight ahead of him now with the lead of Marquez. Lorenzo had a bad weekend!
Hi Mark
Just don't buy the rubbers from them as the USA guys have had loads of problems with their cam chain rollers & rubber parts in general.
Cheers Ash
Would these be any good?
http://www.ebay.co.uk/itm/Mikalor-Supra-Hose-Clamp-W2-Stainless-Steel-Hose-Clip-/270925381673?var=&hash=item3f14694029:m:mXBZ-WDRfJCFTEBu6sWgRNA
The Cruzin image rubbers come with clamps but are Black
Just tried to find on Ebay but not there?
Anyone know whether still selling?
Here you go >>>http://www.ebay.co.uk/itm/Honda-CB750K-K1-K2-K3-K4-K5-Carb-Intake-Set-4-Intake-8-Clamps-21-CB750KINBT-1-/262204292283?hash=item3d0c97fcbb
Thanks Trigger, will they fit my K7 with PD carbs?
I would not know the answer with anything to do with PD carbs. The K rubbers are 36mm ID and 46mm OD were the clamp sits.
Cheers Trigger I"ll check.
