SOHC.co.uk Forums => Project Board => Topic started by: onethumb on September 11, 2016, 11:32:33 AM
Title: Will the tyre clear??? Please help. Start again.
Post by: onethumb on September 11, 2016, 11:32:33 AM
Thanks to yozzer after spending all day yesterday fabricating the seat tray for the new electrics he pointed out to check the clearance.
There's no weight on it as its a bare frame with the back end jacked up all the way under is own weight and no bushes in the swing arm I've got about 45mm. I've bought new Hagon shocks to go on.
Will this be ok?(http://uploads.tapatalk-cdn.com/20160911/7734290c601ad784d51a320a1ed2a18b.jpg)(http://uploads.tapatalk-cdn.com/20160911/cf481d44f9c9b36e00eedba536173378.jpg)(http://uploads.tapatalk-cdn.com/20160911/9caec41d275557dcd7b720f6f1697d67.jpg)
Title: Re: Will the tyre clear??? Please help
Post by: yozzer74 on September 11, 2016, 12:18:51 PM
Just been out and measured mine I've got 90mm distance . And that was tight when checked without springs on .I seem to remember it left about 10mm between tyre and inner of frame
Post by: yozzer74 on September 11, 2016, 12:24:51 PM
I gained some clearance by having a hump in middle bit like the inner mud guard think you can make it out in pictures[attachimg=1][attachimg=2][attachimg=3]
Post by: onethumb on September 11, 2016, 01:39:42 PM
Thanks buddy. I think I might have to cut out a piece. Doh!!!
Post by: onethumb on September 11, 2016, 03:05:01 PM
Yozzer I don't know if to thank you or give up right now. A full day's work 7ltrs of argon and the whole design for the new electrics up the Swanee.
Watch this space.
Title: Re: Will the tyre clear??? Please help. Shock extenders?
Post by: onethumb on September 11, 2016, 04:00:48 PM
Right I've had an idea instead of cutting out and changing the whole design, I've been thinking of using shock extenders, which will suit the scrambler look anyway. Any body used these or do you think they might destroy the ride?
Thanks in anticipation.
Post by: Bryanj on September 11, 2016, 04:02:46 PM
Longer shocks maybe, extenders I wouldn't trust
Post by: onethumb on September 11, 2016, 07:21:08 PM
Bryan I was thinking the same. I'm going to call Hagon tomorrow. If they do one then there will be a new set up for sale. If not I was going to ask Hagon if they do extenders if not yozzer knows a very good engineering company that will be able to sort me something.
I like the look I've got so if I can work something out then that's the way I would like to go.
Post by: yozzer74 on September 11, 2016, 07:26:18 PM
Sorry to put a damper on it but better now then Riding down road .I know it caused me a few headaches.getting it right
Post by: onethumb on September 11, 2016, 07:40:58 PM
No worries buddy, that's why I posted the pictures, I know there are plenty of people on here who've already done theirs and not had the input of others to help them out. If I hadn't of posted you wouldn't of asked and I would of been proper narked after having it powder coated, built up then drop it on the ground only to wonder why it won't move!
So I'll say thank you.
Post by: royhall on September 12, 2016, 05:54:00 AM
Shock extenders or longer shocks may appear to be an easy route out of the problem. But beware that you will be jacking the back up and that changes the geometry so it may end up killing the handling, or even worse be dangerous. Get Hagons expert advice on it first.
Post by: onethumb on September 12, 2016, 07:43:53 AM
It's my first call this morning royhall.
I'm thinking of increasing the shock length from 340-370 the dropping the rear tyre from 110/90/18 to 110/80/18. That will get me the 40mm I need but I'll see what Hagon say first.
Any other ideas out there?
Post by: Trigger on September 12, 2016, 08:05:14 AM
Dropping the tyre size from /90/ to /80/ will only give 5mm difference and then it depends on the profile
Title: Will the tyre clear??? Please help. Shock extenders?
Post by: onethumb on September 12, 2016, 10:17:08 AM
Thank you trigger, the folks on here are tip top.
Spoke to Hagon. Very knowledgeable and helpful.
So information I've gained. You need to allow 80mm travel but Hagon can build you a shock with 60mm on top of this you need to allow another 10mm. So always aim for 90mm (just like yozzer said) for tyre profiles as same tyre sizes don't equate to same size profiles.
Looks like I'm going back to the madness room.
Post by: onethumb on September 12, 2016, 07:31:32 PM
Right so I've thought about nothing else all day and I'm going to star again. Here goes!!!
(http://uploads.tapatalk-cdn.com/20160912/ccc96f579345ff3028a9356d6fe4fd92.jpg)(http://uploads.tapatalk-cdn.com/20160912/f316e2195b9557bc3912a0346bf46118.jpg)(http://uploads.tapatalk-cdn.com/20160912/58c0e3546658894cc7ac26f678ac6cb3.jpg)(http://uploads.tapatalk-cdn.com/20160912/a8aa707a1eedb2c14aa3c32cced8336d.jpg)
Post by: yozzer74 on September 12, 2016, 08:05:40 PM
If I were you I would check the clearance from your tyre to top of frame tubes .I think the problem your going to have is your having a flat seat .can't the m unit go were the battery is and get a smaller battery.and make a new battery box in that location just a thought .
Post by: onethumb on September 12, 2016, 08:21:46 PM
One step ahead of you yozzer. Already have buddy and you're right, the flat seat unit I've made will get hit by the tyre if it bottoms out, so I'm either going to add a rail to the unit I've already made to lift by the 20mm I need or change it.
When I spoke to Hagon today they told me they can change the travel from the standard 80mm to 60mm so there's a chance to get a little back.
I'm thinking of making a box for the m-unit that may fit behind the middle support. If that won't work then I might go that way. Thanks for the idea though I hadn't thought of that cause I've got a bit blinded by the idea of getting it out on its own.
Title: Re: Will the tyre clear??? Please help. Start again.
Post by: yozzer74 on September 12, 2016, 08:40:46 PM
Something like this [attachimg=1]
Post by: onethumb on September 12, 2016, 08:45:24 PM
Yes buddy but attached to the seat so when it's covered it hides the extra support. Now I've got another idea. Cheers dude appreciate the input. Nice one.
Post by: Pops400 on October 20, 2016, 06:55:17 AM
So glad to have read this before starting mine... Hope you are getting sorted.
Post by: onethumb on October 20, 2016, 05:58:47 PM
Thanks pops. It's at the powder coasters as I write this. Had a complete change of plan.
Pictures of the new ideas will be on my scrambler build.
It's good to have the input of others that have gone before you.
