SOHC.co.uk Forums => CB500/550 => Topic started by: Dave1234 on September 17, 2016, 01:42:23 PM
Title: Brake Piston Stuck
Post by: Dave1234 on September 17, 2016, 01:42:23 PM
Hi all, still trying to sort out thr front brake on my 550K3, the wheel caliper piston is stuck all the way in, how do I get it out? I think it is partially seized. Also the front disc plate was rubbing on the fork bottom, I slacken the front wheel clamps and tap the spindle slighty which released it but how much tolerance should you have between the disc plate and fork bottom leg?
Title: Re: Brake Piston Stuck
Post by: Dave1234 on September 17, 2016, 02:19:40 PM
Or what other models caliper fit the 550K3?
Post by: Chris400F on September 17, 2016, 02:52:44 PM
See page 8 of this thread.
http://www.sohc.co.uk/index.php/topic,10585.msg78485.html#msg78485
Post by: Bryanj on September 17, 2016, 03:06:54 PM
If you don't fancy doing it yourself you can post it to me and I will strip it and quote for parts
Post by: Dave1234 on September 17, 2016, 03:37:56 PM
Looks like my grease gun is a different thread.  :'(
Post by: Bryanj on September 17, 2016, 04:49:53 PM
They are all a different thread but will screw in about 1 1/2 turns and will work
Post by: Dave1234 on September 19, 2016, 09:21:07 AM
Thanks Chris, the grease gun trick worked a treat, you learn something new everyday.  ;D ;D ;D
Post by: Dave1234 on September 21, 2016, 06:19:38 PM
Anyone got any ideas on the disc plate and lower fork outer clearance?
Post by: Bryanj on September 22, 2016, 06:25:56 AM
Only reasons for disc rubbing are incorrect assembly or shot wheel bearings
Post by: Rob.b (Rob Birkett - RIP) on September 22, 2016, 09:04:30 AM
hi,
For correct parts and assembly use this link:
http://www.cmsnl.com/honda-cb550k3-four-england_model14671/partslist/F09.html#results
The clearance between disc outer face and fork leg inner should be about 5mm. I couldn't measure mine accurately and its on a CB500K but I'm pretty sure its the same as the parts are mostly interchangeable.
Good  luck with it
Rob
Post by: matthewmosse on September 22, 2016, 12:07:05 PM
That detail has been bugging me, I think Brian is right, in the normal course of things the front wheel will only sit in its proper place, so if its able to move then either a part is in wrong way around or a wrong part is fitted, or you have very knackered wheel bearings indeed. I would suspect wrong bits or a spacer fitted backwards, or the wheel nut wrongly fitted.
Post by: paulbaker1954 on September 23, 2016, 11:44:52 PM
I Agee with Ken I had exactly the same problem when I had new tyre fitted and just took the wheels in . The fitter reassembled the spindle wrongly. Had me scratching my head for ages.
Post by: Dave1234 on September 25, 2016, 10:18:22 AM
I think your right about the spindle being fitted the wrong way round. I have just visited David Silver's museum in Leiston, Suffolk and looked at his CB550 and noticed it was the other way round. I bought the bike earlier this year and have realised quite a few things butchered on the bike. Cheers for all the help.
By the way David has got a nice lot of bikes up there in the museum, even one that used to sit in my garage until a Top Gear presenter bought it then sold it to David. Lol
Post by: AshimotoK0 on September 25, 2016, 06:03:23 PM
It wasn't the CB250K0 was it?
Post by: Dave1234 on September 25, 2016, 06:49:22 PM
No Ash, have another go. Lol
Post by: AshimotoK0 on September 25, 2016, 08:10:36 PM
SS50 perhaps  :D Evidently James May deeply regrets selling/swapping the CB250K0 with DSS ... well he's not having mine!
Post by: Dave1234 on September 26, 2016, 07:20:53 AM
Correct. :)
