SOHC.co.uk Forums => CB350/400 => Topic started by: Erwin83 on November 05, 2016, 07:38:47 AM
Title: Carb settings cb400f with 4-2 exhaust
Post by: Erwin83 on November 05, 2016, 07:38:47 AM
Hi. Sorry if this is the gazillion-th topic on carb settings.
I'm currently overhauling my carbs, and they will go on my standard cb400f (normal air filter etc).
I've replaced my original 4-4 exhaust with a custom 4-2 which I built based on the headers of the 4-4, a custom Y-piece and 2 sporty but not completely open red-tip exhausts.
There are no balance pipes.
I'm wondering if I should deviate from the standard carb settings and jettings.
For instance a different clip height to have a slightly richer mid range?
I've destroyed a 350 engine already once because of too lean mixture. 'D like to avoid another of those  :-[
Any advice?
Tnx
Title: Re: Carb settings cb400f with 4-2 exhaust
Post by: Erwin83 on November 07, 2016, 06:11:57 PM
No-one with a savvy comment or link to information elsewhere on this forum?
 :o
Post by: Laverda Dave on November 07, 2016, 07:05:39 PM
I would go with normal settings for starters. Ride the bike to a dual carriageway, wait for traffic to pass, drop the bike into 2nd or 3rd gear and rev it to max revs for a 1/4 mile and then pull the clutch in and kill the engine at the same time, DONT close the throttle when doing this. Pull over and take the plugs out. If they are sooty the mixture is too rich, grey and it's too lean and you'll need to use a bigger main jet.
Its all trial and error so you'll need a pocketfull of main jets and plenty of time to keep doing plug chops. An alternative is to book a session on a dyno, it might be a quicker option. You are in unchartered territory here making your own pipe so there's no previous data to go on.
Good luck and let us know how it goes.
Post by: Erwin83 on November 17, 2016, 12:42:44 PM
OK, got my Taiwanese carb rebuild kit (the one which people seem to be enthusiastic about). Hopefully I'll be able to get it fitted this weekend.
I'm going for the standard jets.
Post by: Erwin83 on November 23, 2016, 10:22:24 AM
So, after installing the kit in the carbs, and placing the set back on the bike, the float overflow kept dripping. Quite annoying.
Engine runs immediately by the way with the base settings: standard jets, needle at 3rd position, 3/4 mixture out, synchronization eye-balled at peek-through, float heigth at 22mm (old setting was way-off by the way, at 26-28 mm...).
Took the carbs back off and checked if the float needles worked with compressed air. After setting the floats about 1 mm lower (23 mm), all seems well now.
Unfortunately the Taiwanese O-rings for the float cups seem to grow in size. I think I read something similar about the Keyster kits (brass parts OK, rubber parts NOK).
Post by: Laverda Dave on November 23, 2016, 02:14:28 PM
Float height should be 21mm. The Haynes manual is incorrect as I found out to my cost when the carbs overflowed! Thanks to the helpful people on the forum who know the correct measurement.
Sounds like it's going well though.
Post by: Chris400F on November 23, 2016, 02:45:33 PM
I know various people have had a bit of fun fitting these O rings when using the Cruzinimage kit as they are not shaped.
A dab or two of sealant to hold various points in place seemed to help, and I seem to recall warming the rings to help soften them may also have been mentioned.
Post by: Erwin83 on November 23, 2016, 03:14:55 PM
For some reason, I really needed to go to 23mm to get the float needles to work properly. 22 (or 21) didn't work well and made the carbs drip.
Just pressing the floats down (carbs inverted) I found that with 22 mm float height, the float hits the housing bottom before the needle fully closes the fuel flow (easily checked with compressed air). Of course that is with max compression of the little needle spring...
If it weren't for the huge amount of extra work, the best solution would be to do an actual check on the fuel level.
I guess (but I can't explain it) that the buoyancy of the floats may have reduced due to old age?
I tried 'em in the sink though, they all float the same way (height) in water... None of them seemed to be leaking.
Now, I hope my fuel mixture is not influenced to much by the possibly 1-2 mm lower fuel level.
Post by: Erwin83 on November 23, 2016, 03:17:45 PM
Fresh out of the box, they fitted perfectly, even though they are unshaped.
However after 2 days fitted on the carb, they seem to get longer, maybe unsuitable material for use in fuel environment..?
I actually cut 2 of them and decreased the lenght by 3-4 mm to get them just right again.
I'm hoping this O-ring to U-ring conversion won't cause a leak, otherwise I'll have to get new seals.
Post by: Tomb on November 23, 2016, 03:47:16 PM
I usually treat the o-ring getting fuel on it making it swell as a sign that the fuel level is too high, As the fuel level should be lower than the bowl mating face, in an ideal world we shouldn't need an o-ring. For this reason I rarely replace the 0-ring.
Post by: Erwin83 on November 23, 2016, 04:04:23 PM
Yeah, the float bowl drain is clearly higher then the O-ring's position, so it's clear the fuel level was too high.
I hope this is solved by putting the float's at 23 mm now.
Let's see. I hope I don't get home finding my garage smelling like fuel later-on...
Post by: Erwin83 on May 07, 2017, 04:57:52 PM
Continuing on this topic.
So, by now i've:
- set valve clearance
- changed points and set the point gap
- synchronised the carb
- tried several air mix screw settings from 1,5 - 2,5
Situation is:
Bike runs really well.
- good cold start
- good cold idle
- good through the revs
Once hot, everything is still Ok, apart from idle.
Plugs seem to read rich (carbon black, dry deposit)
I'm thinking float level, perhaps go from current 23 to 25 mm (lower the fuel level in the bowl)
Please comment and share wisdom  ;D
Post by: Brian G on May 08, 2017, 11:07:08 PM
I do remember reading that float needle valves in some of the aftermarket carb kits have a slightly different overall height than the originals. That would certainly affect float level. For that reason, I used the original needle valves - which had next to no wear - with my new carb kits.
Regards,
Post by: Erwin83 on May 09, 2017, 01:47:17 PM
Regards,
That is very useful information.
I tested something:
I closed the fuel tap and let the bike run (hot), hence slowly lowering the fuel level in the bowls.
It actually seemed to idle better after a short while.
So i think it's worthwile to try and set the carbs slightly different.
Let's see what happens.
Post by: andut on May 09, 2017, 02:33:14 PM
Hi Erwin,
Just seen this post and your resurrection of another, older post on the same topic.
I think your 'fuel off' test is probably an indication of a rich at idle condition and you may want to consider going down a size on idle jets (likely to give you a bigger tuning change than can be achieved by the idle air bleed circuit) if your float height adjustment does not provide a permanent fix.
I also had similar O ring growth with the Keyster kits and changed them for viton seals from ebay (seller gerben1956) that are much more durable.
Andy
Post by: ka-ja on May 09, 2017, 04:40:02 PM
Don't forget that fuel level alteration also effect the mix over the whole range, dropping the fuel level could result in too lean a mix when on larger throttle openings, needless to say very damaging to the top end. As already suggested, it may be more prudent to experiment with smaller pilot jets
Post by: Lynx on May 10, 2017, 05:04:25 PM
If it's just rich at idle all you have to do is open the idle air screws 1/4 turn.
Post by: Erwin83 on May 21, 2017, 06:42:42 PM
Changed the float level to 24mm now..... And we've got reliable idle!
Also a nice coffee brown color on the plug.
Still with a hot engine (seriously hot), it drowns on pick up from idle to any throttle.
Will look into the air screws a bit see what that does.
Out playing with a bigger sister today:
(https://myalbum.com/photo/AVn4Njb8u25G/1k0.jpg)
Post by: Clem2112 on May 22, 2017, 10:00:50 AM
On the float bowl seal issue.
The ones I have used also swell up and grow 5mm in length but have not degraded visibly.
A few hours to dry out and they shrink and fit the groove again.
I must have fitted the same set many times and they have never leaked.
The fuel level (21 mm float height) is supposed to be a few mm below the joint face but the petrol will still wet the seal in normal use, banking over, accelleration or just through evaporation etc.
