SOHC.co.uk Forums => CB500/550 => Topic started by: Wenman on January 25, 2017, 06:45:09 PM
Title: Cb 550 motogadget m unit
Post by: Wenman on January 25, 2017, 06:45:09 PM
Hello all.. I'm new to this forum and currently have a '77' cb550 supersport as my first cafe build! I'm getting through the project and really enjoying it! I am fast approaching the wiring harness and several attempts have been made in cleaning it up but I am losing patience! I would like to fit everything under the seat in a fabricated tray but looking at it every night with a puzzled face as to how it's going to fit is getting tiresome!
I really like the look of the motogadget m unit and was wondering how easy this is to fit with stock everything.. switches ignition controls lights etc! The only aftermarket component I have is a universal speedo with all the idiot lights built in!
Any experiences advice would be very welcomed! Thanks in advance!
Alan
Title: Re: Cb 550 motogadget m unit
Post by: Niko on January 25, 2017, 07:13:29 PM
I can't help....but I will be going down the m unit route too....
Post by: philgresty on January 25, 2017, 07:19:58 PM
Alan
Im running a motogadget on my cb550, installation is easy once you get your head around how everything needs to be connected. charging system is the only real pain with it, but i can advise you on that if you need help. Stock switches wont work with the m unit, youll have to use motogadget switches or any other switches which are momentary ones, the m uit doesnt like the toggle switches for the indicators, doesnt recognise when they are cancelled. Everything else stock will work fine.
Post by: Wenman on January 25, 2017, 08:25:14 PM
Awesome thanks phil! Can you or anyone else recommend some decent switches that won't break the bank? I'm pushing the budget on the m unit but can't really push any further on the wiring? Although they are very pweety!!
Post by: gordo on February 06, 2017, 02:13:00 PM
You can use stock switches but have to select that setting in the m-unit menu. Also you have to wire them to switch ground not 12v.
Post by: philgresty on February 06, 2017, 09:44:22 PM
Tried it, didnt work for the indicators, switching between high and low beam with the toggle was fine though
Post by: mike the bike on February 06, 2017, 10:01:00 PM
Try removing the ball bearing in the indicator switch so it doesn't stay on L or R but acts as a momentary switch.
Post by: Chris400F on February 07, 2017, 08:58:04 AM
If the 'momentary switch' turned the indicators on how would you then turn them off? Same switch action again?
Post by: mike the bike on February 07, 2017, 09:38:06 AM
Gooe question.   Timed probably but no idea how to cancel them
Post by: gordo on February 07, 2017, 10:37:39 AM
From the manual you can set what controls you have on the bars.
7.7 Handle Bar Controls Three different types of handle bar controls are compatible with m-Unit. The particular type which will be used with m-unit must set in the setup menu.  Configuration A) – 5-push button controls - turn lights left  - push button - turn lights right  - push button - low beam / high beam - push button - start    - push button - horn   -  push button Configuration B) – Harley Davidson and BMW controls - turn lights left  - push button - turn light right  - push button - low beam / high beam - switch - start   - push button - horn   -  push button Configuration C) – most Japanese and European motorcycles - turn lights left / right  - 3 way switch  - low beam / high beam - switch - start   - push button - horn   -  push button configuration D) – new Ducati models - turn lights left / right  - 3 way switch  - low beam / high beam - push button  - start   - push button - horn   -  push button configuration E) – 4-push-button controls - turn lights left  - push button - turn lights right  - push button - low beam / high beam - push button  - horn   -  push button - start   = left turn + light simultaneously - kill switch   = right turn + light simultaneously  In case of using the OEM handle bar controls together with m-Unit; head light flashing push button is not applicable. There is also no possibility to switch the parking light by the m-Unit. Additional safety switches like side stand switch have to be connected as shown in chapter 7.9.
Post by: Chris400F on February 07, 2017, 10:39:57 AM
Hmmm ..... Not sure I'd fancy just having them on a timer. Not sure about the legality aspect either.
I seem to remember that on the CB-1 (NC27) I used to own the indicator was a 'momentary' switch which you then pressed in to cancel the indicators.
Obviously you couldn't do this with the standard switchgear though.
Post by: philgresty on February 07, 2017, 10:48:50 AM
to cancel you press the button again.
tried it with another non honda toggle switch for indicators and that didnt work either
Post by: totty on February 07, 2017, 10:49:41 AM
The push to cancel switch on most newer Honda's is much nicer to use, especially with numb hands.
Post by: Chris400F on February 07, 2017, 10:59:18 AM
.... push button Configuration C) – most Japanese and European motorcycles - turn lights left / right  - 3 way switch  ....
I'm reading this as basically three momentary switches (left / right / cancel).
If this is correct there is no way the standard switchgear will work as an additional terminal/contact is required.
Edit: Reading the M unit manual post again it looks as if some configurations use a push button for left indicator and another for right.
This would seem to use a 'push on push off' operation, in which case using the standard switch as a 'momentary' switch may work.
You would need to check all switches worked the right way for the selected configuration.
Post by: gordo on February 07, 2017, 12:43:45 PM
M-unit uses ground signal to switch so what would be a 12v feed to the switches is grounded instead.
Post by: mike the bike on February 07, 2017, 06:13:11 PM
Try grounding the grey wire that goes to the centre of the switch and have the light blue & orange wires from the switch going go the M unit.
Post by: Niko on April 25, 2017, 01:26:57 PM
Alan
It does if you configure them in the lighting menu.....works just fine.
Post by: Niko on April 25, 2017, 01:27:29 PM
Alan
