SOHC.co.uk Forums => CB350/400 => Topic started by: kevski on February 04, 2017, 12:40:47 PM
Took the 350 for it's MOT this morning passed no problem they adjusted the headlight aim, took it for a little run to warm it right through after, little bit of smoke, not unexpected as it had probably stood for many years doing nothing very happy with the old girl but i will change the front sprocket for a 1 tooth larger to give it a little more on the top end.
Well done, good weather for it too.
great its back on the road,I would leave it till its run a little more before altering the gearing,you need to check if it will hit the redline in
top before you increase the size of the gearbox sprocket,
