SOHC.co.uk Forums => CB500/550 => Topic started by: firet49 on March 21, 2017, 05:40:39 PM
Title: Cb550 steering lock
Post by: firet49 on March 21, 2017, 05:40:39 PM
Hi
Can anybody tell me how the steering lock works that mounts on the side of the headstock.
I have bought a new lock which has slotted in ok and I have the spring behind it .
Do I need to push in and turn some way to get it to lock???
Title: Re: Cb550 steering lock
Post by: hairygit on March 21, 2017, 06:42:28 PM
Yes, turn the key slightly clockwise, push on the end of the key so the barrel moves inwards, then return the key to it's original position to lock the barrel in the depressed position. Your steering should now be locked.
Post by: hairygit on March 21, 2017, 06:46:30 PM
One other thing, when unlocking, ALWAYS remove the key before straightening the handlebars, otherwise the fork leg can bend or snap the key off on the lock, which is a right pain to sort!
Post by: firet49 on March 21, 2017, 07:04:22 PM
Thanks I'll give it a go later...
Post by: Chris400F on March 21, 2017, 10:33:56 PM
Assuming it's the same as other models handlebars should be turned to the right in order to lock.
Post by: firet49 on March 21, 2017, 10:41:27 PM
Thanks I now am able to lock the steering
