SOHC.co.uk Forums => CB350/400 => Topic started by: paul G on May 09, 2017, 08:19:43 AM
Title: Main jet O rings
Post by: paul G on May 09, 2017, 08:19:43 AM
Hi all,
               Anyone know the size of the O ring on the main jet for the 400/4
Cheers,
Title: Re: Main jet O rings
Post by: andut on May 09, 2017, 08:43:30 AM
Paul,
I found a measurement of 3.5mm ID and 1.2mm X section from an online search, butg have never checked it !
Andy
Post by: Bryanj on May 09, 2017, 04:27:00 PM
original part no 16177-551-004  4.2x1.1mm
Post by: andut on May 09, 2017, 06:23:50 PM
Part number description #@%$'s a year old random Google search !
Post by: paul G on May 09, 2017, 08:48:13 PM
Found this on the SOHC/4 owners club.
CARB O-RING SIZES: CB350, CB400, CB500, CB550
When rebuilding carbs on the old Honda fours with press-in main jets, you will often find that all the metal parts are fine after a good cleaning, and all that you really need to buy are new O-rings. Honda doesn’t sell the individual O-rings separately….
instead you have to buy a complete carb kit at $10 to $15 per carb. I found an industrial O-ring supplier who was willing to do small-volume counter sales, and was able to get new O-rings at about 50 cents per carb. Sizes are:
Main Jet: 1.2mm cross-section x 3.5 mm ID
Float Seat: 1.5 mm cross-section x 5 mm ID
Float Bowl Drain Screw: AS568-009 (7/32″ ID x 11/32″ OD)
Post by: Bryanj on May 10, 2017, 07:03:33 AM
The sizes and separate part number i quoted are from a very early parts book where everything is seperate
Post by: paul G on May 10, 2017, 12:29:23 PM
Thanks Brian.
