SOHC.co.uk Forums => CB750 => Topic started by: yozzer74 on June 22, 2017, 10:36:11 AM
Title: Stator cover oil leak
Post by: yozzer74 on June 22, 2017, 10:36:11 AM
Hi ive noticed a little oil on the bottom of my stator cover it's not coming from the 3 bolts on the front of the cover I'm going to replace the gasket but how much oil should be in there if any ??
Title: Re: Stator cover oil leak
Post by: MrDavo on June 22, 2017, 12:31:55 PM
Some. There is no seal on the #1 main bearing, so some oil can come out and drain back from the stator compartment into the crankcase. What there is will lubricate the starter gear by splash, I was quite surprised when I changed the 3 screws holding the alternator stator and didn't tighten them enough - I put the bike on the side stand after a test ride and oil ran from the screw holes, luckily alerting me to the problem before any damage was done to the stator.
Post by: yozzer74 on June 22, 2017, 12:34:19 PM
I've just taken cover off there must have been a good pint of oil in there should I have drained oil off first
Post by: yozzer74 on June 22, 2017, 12:36:09 PM
Pic [attachimg=1]
Post by: Bryanj on June 22, 2017, 01:54:04 PM
Thats because you took the gearchange cover off as well
Post by: yozzer74 on June 22, 2017, 01:57:57 PM
I removed the stator cover first and loads of oil came out of there
