SOHC.co.uk Forums => CB350/400 => Topic started by: watty51 on November 11, 2017, 04:30:13 PM
Title: Spark plug Caps
Post by: watty51 on November 11, 2017, 04:30:13 PM
Does anyone know if the Spark plug caps from David Silver are 5000ohm suppressed   www.davidsilverspares.co.uk/CB350-FOUR/part_28361
Im just fitting a Boyer Bransden Electronic Kit 00289 and the fitting guide says the caps must be to this spec.
Many Thanks
Title: Re: Spark plug Caps
Post by: Seabeowner on November 11, 2017, 04:39:31 PM
The 05 is 5kohms, so yes.
The NGK plug catalogue is here:
https://www.ngkpartfinder.co.uk/files/NGK_Spark_Plug_Covers.pdf
Post by: watty51 on November 11, 2017, 04:53:24 PM
Thanks for the quick reply.
Thought the VD05F partcode had something to do with it.
Just checking
Post by: kevski on November 11, 2017, 07:49:33 PM
Do not use resistor plugs with these caps it will create bad running.
Post by: watty51 on November 11, 2017, 08:06:54 PM
I am using NGK D8EA Plugs at the moment. Will these be ok
