SOHC.co.uk Forums => CB350/400 => Topic started by: K2-K6 on December 05, 2017, 09:05:04 AM
Title: 400 Four detonation
Post by: K2-K6 on December 05, 2017, 09:05:04 AM
Alright,  I know I " go on about it" but been looking at why I feel detonation can easily occur on this engine given the right / wrong conditions.
As others pointed out you normally associate lean mixture with something like this,  which is not obviously the case if jetted properly,  you'd have thought?
A characteristic of slide carbs is that you can create it with how you ride,  even if setup is correct.
[attachimg=1]
Above should be a dyno trace that Jensen has kindly shared of his 400 Four running in 4th gear with throttle rolled open in that one gear to build the power curve you see in top traces.
The really interesting bit is the lower trace,  left scale is mixture with rpm along the bottom. It's obvious from that peak leading up to 4000rpm that it's running toward an over lean condition. Complete burn is considered to be 14.7 parts air to 1 part fuel. Most engines won't get that close. During acceleration you'd expect closer to 12 to 1 to make it move,  with cruising state in between the two.
It's not a wrong setting on here,  just characteristic of running from low rpm to high in one gear which is needed for the dyno plot.
What it does is the vacuum the engine draws at low rpm with throttle wide open cannot match the flow the carb venturi is making,  resulting in loss of vac on the main jet,  and so less fuel than ideal is pulled from float chambers ( it's this bit that PD carbs fill in with accelerator pump,  clever a?)  you can't jet your way out of it as the carb and main jet is almost fully open. It's really a failure of slide carbs used in this way and what would be termed "lugging " the motor in high gear.
In addition,  the ignition advance reaches max around 3000rpm and quite early for full load application ( more suited to cruising on light throttle to give good economy)  so in that lean peak area you've also got probably too much advance for a short period.
Put those conditions together,  perhaps riding along into a headwind,  fith or sixth gear,  trying to keep up speed at lowered rpm and you've got classic detonation. Riders with experience would recognise it's not pulling properly,  but if the circumstances are held like that without the engine accelerating through that, it will most likely detonate. It'll only take a few minutes like that to start the destruction of the pistons and rings.
You can't jet it differently,  it's just how you ride it. They need to be revved if you want them to go.
You've either got to back down the throttle or drop gears and spin it to higher revs.
Title: Re: 400 Four detonation
Post by: ka-ja on December 05, 2017, 09:13:46 AM
Even when relatively a new bike (got mine in 1979) you had to use them above 5000/6000rpm to gain decent performance.
Post by: Nurse Julie on December 05, 2017, 09:32:49 AM
That's really interesting Nigel. So, going back to the mess on my pistons / rings on my engine strip thread, it would make sense to me how my engine got in such a state. If a PO had not ridden it as the bike likes to be ridden for optimum air / fuel mixture ie, high revs and the engine 'pulling' a majority of the time then it makes total sense how the damage had occurred. I have said many times that the CB400/4 likes to be ridden like a 2 stroke, high revs and minimal lugging and I can see how riding it for long periods in the wrong gear / too lower revs can start a chain of events leading to damage.
Can I ask you to put a copy of this on my engine thread as I think it is a very good explanation of how the chain of events could have lead to the damage on mine.
Post by: K2-K6 on December 05, 2017, 10:46:33 AM
Transferred to your post Julie, it's a bit awkward for cut and paste on the tablet I use but think it's done the job ok.
There's something with these engines as they are so refined and benign ticking over and just tootling around that it convinces some that they don't like revs,  but they were built to do just that,  as you point out. Honda did a remarkable job in combining such a range of response in them,  and such tough little things to survive the effects you had in yours.
Larger engines will generally have enough torque to pull it through sub optimal sections like this,  but the smaller one's have to be driven much more like a small racer really. Properly oiled they don't have any real problems but people convince themselves that revs are damaging.
Nigel.
Post by: taysidedragon on December 05, 2017, 08:34:40 PM
I'd never really thought that the way I ride would affect the fuel/air ratio. Very enlightening, thanks.  :)
Post by: Mr-Gear on December 20, 2017, 12:29:07 PM
What taysidedragon said.
Good technical content. Thanks for Posting. I'm sure it will have a subconscious affect on the way I ride my 400 from now.
Post by: K2-K6 on December 20, 2017, 03:17:22 PM
I re-read an initial road test published for the 400 when introduced to the UK,  they just seem obsessed in some older journalism of performance at low rpm,  ie lugging it around. They often talk of how the engine will accept top gear at whatever rpm is deemed impressive,  it's no wonder sometimes that these are ridden originally in such a way.
It's funny that they seem to live in mortal fear of higher rpm,  guess that's from brit bike experience. Although oddly they comment that they don't think it needs a sixth gear.
To get to 10,000rpm, the carbs are sized relatively large for the engine capacity to get that max flow,  so they need to be used with a little moreover finesse to make sure you don't drop into that lean hole at low rpm.
Cars have always coped with this effect by using composite ignition advance to avoid detonation. Swing weights form the initial advance,  plus vacuum from inlet manifold pulls the total up to optimum spec. But when you tread on the throttle at low rpm the vacuum drops away and so does the supplementary advance. This happens until the throttle starts to close again or the engine catches rpm catches up with throttle position,  at which point vacuum builds again. So part throttle cruising at high vac gives max advance and best economy,  but the risk of detonation is avoided automatically.
The bikes of this era,  it's all down to the rider. The 750 has enough torque to not get bogged down at lower rpm. The 500  obviously less but appears to be able to avoid it as well.
The 400,  if you got it in 5th or 6th perhaps with a passenger on a long uphill will most likely sit there not being able to gain any significant rpm. So the risk is much greater.
Being sensitive to not getting any rpm increase when winding open the throttle is just part of riding them I guess.
Post by: K2-K6 on January 11, 2018, 09:28:23 AM
Some more detail in this link that expands what happens and the timescale over which an ignition spark occurs
http://www.crypton.co.za/Tto%20know/Ignition/burn%20time.html
The devisions going across the illustration are in milliseconds.  Contrary to many views that a spark should happen in one big powerful chunk,  it's interesting to see how long the process is extended and that different systems will have a bias to give the engine designer the characteristics that are needed to run a particular combustion chamber design.
The Honda system appears to favour an extension of spark event to match the range in which it works and may be important in mitigating against early detonation tendency.
Post by: K2-K6 on January 11, 2018, 09:35:37 AM
To accompany the above post,  another link that I feel gives a good account of what the burn event in a combustion chamber really looks like.
http://www.sdsefi.com/techcomb.htm
This era of Honda combustion chambers have most similarities with the "hemi" type referenced in American V8 engines,  albeit in miniature. One of the areas of interest is just how long the combustion takes in terms of crankshaft degrees. The may be smaller bore but they run more outright rpm than a car engine so have very similar advance requirements to get the combustion completed in the time available.
Post by: Trigger on January 11, 2018, 09:57:15 AM
This was one of the problems with the old Triumph twins. With the dome shape piston and the spark plug to the side, detonation was never getting to the opposite side to the plug in the combustion chambers . That is why when you change the oil on a triumph twin, you always can smell fuel in the oil, which hasn't been burnt off.
On the Triumph race engines I always blocked off the original plug hole and relocated it to the top of the engine, this gives a better detonation and power ;)
Post by: K2-K6 on January 11, 2018, 10:14:06 PM
I guess it's  not of mainstream interest but I'm fascinated by this stuff.
I like seeing things others have built up or modified running well. Some of the renovated bikes or specials I see out at a bike meet sound so well put together and run so sweetly,  they obviously know what they are doing.
Post by: neilg on January 12, 2018, 01:04:28 PM
  I had similar but different, (if you get my drift), with my old Air Head BMW. When we lost leaded fuel the pre ignition was so bad I seriously worried about what damage was being done. I had already converted the valve seats but never envisaged this would happen at the time. I ended up twin plugging the heads and fitting Delorto pumper carbs to give it an extra squirt on acceleration. Also the timing unit was altered to give a different advance curve. The carbs were set up on a dyno and since then no problems in the last 15 years or so. (I.m looking for some wood to touch)
Post by: MrDavo on February 02, 2018, 05:50:37 PM
Quote
I had a T110 with centre plugs, and was never really sure why they'd bothered until I read this.
Quote
Yes because they happily blew themselves to bits when you revved them hard. Been there done that, still got some of the wreckage. Also the resulting vibration from running at high revs would make any number of random cycle parts break in sympathy, just for a laugh. If I went over 85mph at night on my A7SS, the vibration would blow the headlamp bulb, plunging me into instant and terrifying sudden darkness.
BSA A10 conrods had a hole drilled through on one side, to provide oil to the main bearing from the big end (or maybe to oil the big end, I don't remember now). If you went fast enough you soon found out what could possibly go wrong with that, in a big way.
(https://www.a7a10.net/forum/index.php?PHPSESSID=pumabpjq8elais10p2onav6r97&action=dlattach;topic=3337.0;attach=21231;image)
I think you're right it just feels wrong to rev the potatoes off any four stroke after an upbringing like that, whereas to someone accustomed to two strokes (don't rev them and they foul the plugs) and small jap bikes it would be second nature.
Post by: Drew400 on February 04, 2018, 11:08:41 AM
Thanks for this interesting thread K2-K6,
I have very limited technical knowledge but understand the main principles being discussed.
Does having Boyer Bransden electronic ignition have any bearing, good or bad, on your assertions?
Ta, D.
Post by: K2-K6 on February 06, 2018, 09:36:48 AM
Good question Drew, I was thinking about that too.
It's something that's not claimed generally by most types of system. They normally go with fatter / hotter spark, improved starting, improved high speed accuracy etc, making it difficult to see if they have considered more in depth issues and completed a design to address something very specific. They appear, in this field generally,  to cover this sort of stuff with words like "improved driveability" which could mean any number of things.
The Boyer has always seemed a very competent system but ultimately it may be worth posing a specific question to them to understand, in their view, how they approach something like this.
It's complicated by the Honda original, in my view, being a very good mechanical design with some clearly very subtle qualities that are very hard to improve without very specific knowledge.
The area that would seem in the original fit to be most influential is the length of spark,  ie duration of the spark event. Honda appear to have designed in a specific length that would benefit their combustion chamber requirements. The bigger is better school of thought may trip up on something like this.
This is pulling together what I view as happening to produce error;  with a still relatively low piston speed at around 2/4000rpm the ignition reaches its maximum advance. The time of piston travelling during the period of spark initiation until piston reaches tdc,  if it's more time than spark duration,  then the spark will have completed prior to tdc. It looks to me that Honda are trying to cover this area of interest by designing in a "long" spark.
If a replacement system shortens the spark,  it looks like this area is the most vulnerable to complications. So anyone claiming a shorter ignition duration will appear suspicious.
It's notable ( I think it's correct)  that Honda delay the max advance rpm point for the 400 Four above those of the 500 / 750 so they are also massaging this point as well to avoid the detonation as I view it. I think the Boyer doesn't change this spec but also uses it for the whole range of these four cylinder engines.
If you then add in that mixture curve that we can see has the possibility of going very lean (peaks about 15.7 parts air to fuel ratio) it all meets at this critical point,  making it very marginal to get a clean combustion event completed.
Post by: hairygit on February 06, 2018, 09:49:32 AM
Ultimately I think the issue is down to allowing the engine to labour at high throttle openings at low RPM, these Honda's are designed to rev, the max power is developed at high revs, and restrained use of the throttle at low RPM in high gear is the answer. If you want to go faster, knock it down a gear or two and let it rev freely.
Post by: K2-K6 on February 06, 2018, 12:53:42 PM
Agree,  hairy.
Being more informed about why you've got to do that and take account of how they run will avoid giving problems.
It's fairly common though, as discussed, to impose or overlay things like the British bike experience onto these bikes though,  particularly as newcomers to these generally see them all as old bikes with no real distinction or separation of their care.
I was speaking recently to a 750 K6 rider at a bike meet, really nice example. I said it sounded good and asked as to how it was running, he replied that he'd given it a bit of a thrashing on the way there "and took it right up to 5000rpm" which really is nowhere near using the full range.
That fuel trace at the beginning is run in 4th gear,  so knocked down two from top. The essence is, I suppose, that if you find yourself with dropping speed and you continue to open the throttle more with little or no increase it should alert you to back out of it or drop ratios until it does what you ask of it.
Interesting that two more, in addition to Julie's,  have turned up on here with apparently the same issue. Plus the two cylinder heads of 250 /350 engines over on another thread with very close failure type.
It certainly makes a different view of running them on pod types airfilters, and trying to jet them without a dyno facility look easy!   :o (definitely a joke :) ) if it's not understood about the original intricacies,  how can a competent decision be made? Particularly if you change the carefully set vacuum gradient that Honda sent it out with.
I suppose this thread is a bit of a walkthough and illumination of what really affects them.
Post by: Drew400 on February 06, 2018, 04:33:47 PM
Thank you again.
Any excuse to 'thrash it' over 5000rpm sounds good to me.
Common sense tells me to drop a cog (or two) when the power runs out... two-up, headwinds, etc. But that's true of every bike I've owned.... apart from the XS1100 that could torque it's way out of prison!
Cheers, D.
Post by: Rudi45 on February 21, 2018, 03:08:57 PM
Hello,
i´m new here, but I will post later on in the new member introduction.
Excuse my poor technic English.
I will show you my Dyno run,  direct after rebuilding the Motor with new piston an so on.
I hope you can read this
(https://up.picr.de/31507764ul.jpg)
Drehmoment = torque
Luft, Kraftstoffverhältnis = Air-Fuel
Max. Leistung = Max power
Regards
Rudi
Post by: K2-K6 on February 21, 2018, 07:10:38 PM
Hello Rudi,  welcome to the forum.
Your English is fine and I think much better than German is spoken by us over here. So all ok.
Thankyou for posting your dyno run printout which is interesting as part of the subject discussed on this thread.
It'll be interesting to find out more about your engine and if you have experienced something like the original problems that initiated this thread.
Nigel.
Post by: Nurse Julie on February 21, 2018, 07:15:55 PM
Hi Rudi.
What happened to your engine to make it require a rebuild?
Post by: Rudi45 on February 21, 2018, 07:31:34 PM
[attachimg=3][attachimg=2]Please wait :)
I´m writing on an other PC. It needs time to do in English.
Stay tuned 8)
Rudi
Post by: Rudi45 on February 21, 2018, 07:35:44 PM
excuse for the lot of pics.
But I will learn :-[
Post by: Rudi45 on February 21, 2018, 08:10:07 PM
Hello Nigel and Julie
this is a very long story.
My first  Bike was 1975 a cb 400 four. Two years later I sold.
In the meantyme  I had a lot of different Bikes and a long nothing.
8 years ago I thought about a new, used cb 400 four at ebay.
I´ve done everything  by myself. Only the Motor a specialist had done.
After 500 Km  , when I start the cold engine it smoked blue for nearly 5 minutes.
When the motor reached Temperatur there was nothing.
The specialist changed once more the piston rings. To original Honda!!??
But after 500 Km , the same procedure. Smoking like crazy.
I was so angry, Iwould like to sell this Honda.
Then I had an Idea. In the near of my City is an old Honda dealer, I contacted him.
He has now putted in Pistens, rings.  0,75 .Everything original Honda parts.
I brought him the disassambled Bike. He opend the motor and was looking everywhere.
I hope, now everything is now okay. This bike was until now very expensive. Incredible.
It´s a pity, the weather. Okay it´s winter. Therfore it stands in my flat.
I will put a few fotos without comment.. They show the motor  Inside after 500Km.
Regards
Rudi, now and 1976
(https://up.picr.de/30453441sp.jpeg)
(https://up.picr.de/30516629dq.jpeg)
(http://up.picr.de/30675247vp.jpg)
(http://up.picr.de/30569699ut.jpg)
(http://up.picr.de/30540594un.jpg)
(http://up.picr.de/30540585vm.jpg)
Post by: Nurse Julie on February 21, 2018, 08:17:29 PM
Your English is good Rudi. Nice photos, you have not changed since 1976  ;D ;D
Good place for bikes in the winter....indoors 👍👍👍👍👍
Post by: Rudi45 on February 21, 2018, 08:23:40 PM
Thanks Julie,
in 1976 i was 31 :'(
Mr. Google is my friend ::)
Rudi
Post by: Johnwebley on February 21, 2018, 09:14:10 PM
  welcome Rudi,enjoy the fun world of sohc.
 back on subject,my 500 had similar issue about 16K miles ago,the piston on the RH outer was chewed,and rings gone,the one next to it,has a broken ring only,piston OK,other two were ok,.
 it was put down to over revving when cold ,maybe detonation,no damage to bores,just one new std piston and 4 sets of rings
  PS,I have emailed Boyer explaining the discussion and asking for the various advance curves and spark duration.
 hopefully they will be interested
Post by: Johnwebley on February 22, 2018, 05:18:28 PM
  brief reply from Boyer,basically saying nothing,I am guessing commercial secrets ,but they did refer to the "wasted" spark,
 not sure how that helps? or not .
Reply
Re: Advance curve
B
Boyer Bransden Electronics Ltd <help@boyerbransden.com>
 Reply
Today, 15:30
You
Re: Advance curve
 Reply
Today, 15:30
You
Inbox
Thank you for your enquiry, sorry we don't publish this information as we have a few secrets that do give us an edge. You may note  that we fire all cylinders every 180deg, this requies a little trickery, but it works.
Regards Tech Dept.
Sent from Samsung tablet
Post by: K2-K6 on February 22, 2018, 09:26:56 PM
Thankyou for asking them John, I guess they're in a position that's awkward from a commercial point of view.
No answer either way suggest they don't have one though. I worked with someone who always got hold of a manager when they came out on the factory floor and cornered them with awkward questions. If they didn't give an answer, her reply was "we'll just make something up" which generally made them nervous.
To be absolutely fair, it's a carburettor initiated problem as I view it and asking an ignition system to cope with that error is unlikely to happen in its entirety. The question for any aftermarket supplier is,  does your system with its change in specs,  match / shorten / lengthen the spark duration?
It's a very valid point if we believe it could lead to this type of engine damage.
Hondaman has specifically built his switching to match the Honda original,  that seems to be the most competent answer I've so far seen.
Their (Boyer) firing at 180degree intervals appears related to emissions, I can't see the relevance in this context either John.
In common with Hondaman,  (and by using the 400 advance curve for all the fours)  they delay the max advance for the 500 and 750 a little,  so that may assist the larger capacity examples in this area. Doesn't make make any difference to our little collection of damaged 400s though.
On current engines with knock sensors,  when detonation occurs then the first reaction is to retard the ignition until it stops. It's this that limits performance of high output motors when they are run on lower octane fuel. Keeping them from damaging themselves reduces output.
I cover some more things in next post.
