SOHC.co.uk Forums => CB350/400 => Topic started by: Golfcarmad on February 10, 2018, 03:35:11 PM
Title: Split swinging arm help n advice please
Post by: Golfcarmad on February 10, 2018, 03:35:11 PM
Ok stripped bike frame down to last nut n bolt,engine out. Swinging arm is split on left hand side.before I try to source original (feel free to offer 1 if available) will an alternative fit off different model? Thanks Paul
Title: Re: Split swinging arm help n advice please
Post by: Nurse Julie on February 10, 2018, 03:43:36 PM
Is it a F1 or F2 frame?
Post by: Golfcarmad on February 10, 2018, 03:51:18 PM
Frame no. Cb400f 1087284.  V5 1.10.77 has comstars not spoked
Post by: Nurse Julie on February 10, 2018, 03:56:05 PM
Still confused by those numbers, should have CB400F2 ........at that date of reg. Dies it have the rear foot pegs on the swing arm or the frame?
Post by: Golfcarmad on February 10, 2018, 04:02:18 PM
No f1 or f2 however pegs on frame so must be f2??
Post by: Nurse Julie on February 10, 2018, 04:06:16 PM
Yes, would be F2 then. Is there any way you could get it welded?. I think only a CB400 swing arm fits these bikes, unless someone on here knows different.
Post by: hairygit on February 10, 2018, 04:08:05 PM
Not sure M.O.T. man would accept a repair to a swingarm.
Post by: Nurse Julie on February 10, 2018, 04:10:26 PM
Good point Hairy, the voice of experience and common sense there  ;D
Post by: hairygit on February 10, 2018, 04:14:02 PM
Might be worth seeing if DK have one, they break loads of imports, even if its an F1 part, you can grind the footrest brackets off before painting/coating.
Post by: Golfcarmad on February 10, 2018, 04:16:25 PM
Bad split a lot of rust would post photos but cannot get them to resize small enough Tks for such quick response looks like California searching?.
Post by: Golfcarmad on February 10, 2018, 04:17:44 PM
Will try DS as suggested
Post by: hairygit on February 10, 2018, 04:19:46 PM
No, D.K. Spares, DS is David Silver Spares, his stuff is new.
Post by: hairygit on February 10, 2018, 04:24:28 PM
Here you go, good old e-bay, just under £30 Inc delivery, buy it now. Item number  112772084158  and heres a link if it works!https://www.ebay.co.uk/itm/Honda-CB-400-1977-Rear-Swingarm/112772084158?hash=item1a41bd71be:g:jmgAAOSwsABaZ5e2
Post by: Nurse Julie on February 10, 2018, 04:25:05 PM
Try this photo resizer. Plenty of others available but it's the one I'm using at present
https://www.microsoft.com/store/productId/9NBLGGH4NMQD
Post by: Nurse Julie on February 10, 2018, 04:35:20 PM
You could try Neil, otherwise known as BikePusher, he may be able to help.
classicsparesrecycling@fastmail.fm
Post by: Golfcarmad on February 10, 2018, 04:49:44 PM
Thanks hairy different Honda 400 but at that price it’s worth a punt so bought it cheers
Post by: Nurse Julie on February 10, 2018, 04:59:17 PM
You don't hang around  ;D
I'm sure it won't fit a CB400/4 though, it looks a different shape and the ends of the swing arm are 'open' on our bikes where the chain adjusters mount. Also, where the bolt and collar go through is one solid tube on the CB and not just 2 small round collars.
Post by: Golfcarmad on February 10, 2018, 05:06:58 PM
I can get a spacer made for long bolt at work will keep looking for original though
Post by: Nurse Julie on February 10, 2018, 06:22:47 PM
If your original swing arm isn't too far gone, could you not get that repaired at work? ( I know it's not the optimum solution Hairy but at least it fits the bike !!!)
Post by: Bryanj on February 10, 2018, 06:38:24 PM
 As an ex MOT man a properly repaired swing arm is OK
Post by: Laverda Dave on February 10, 2018, 07:06:01 PM
Steve Cooper at http://www.400fourbits.co.uk/ has two swing arms although both are early type with footrest brackets but these can be ground off prior to paint. The second swing arm has been freshly powder coated so maybe not a good idea.
I don't know how much he's asking for either.
Post by: AshimotoK0 on February 10, 2018, 11:01:20 PM
Just picked this up ...beeen out all day ... I have one from a really  low miler but  can't remember for sure if it's off an F1 or F2  as it's at my stash ..would sell for same price as the eBay one. Definitely off a 400/4 though.
Post by: Golfcarmad on February 10, 2018, 11:02:17 PM
Hi Laverda I will find out many thanks.
Re repair of own arm=no chance
Happy to keep looking
