SOHC.co.uk Forums => CB350/400 => Topic started by: ogri211 on March 28, 2018, 09:25:21 PM
Title: Plastic 5 pin plug for Ignition
Post by: ogri211 on March 28, 2018, 09:25:21 PM
While checking my wiring on the rebuild I noticed that my ignition switch was connected to the loom with 5 individual spade connectors, this would have originally been a multi plug does anyone know if I can buy the correct one of these plugs to fix it to the switch.
Title: Re: Plastic 5 pin plug for Ignition
Post by: Deano400 on March 29, 2018, 09:58:54 AM
Steve will cut plugs off old harnesses that you can splice in.
http://www.400fourbits.co.uk/
Post by: Deano400 on March 29, 2018, 09:59:42 AM
Alan can probably supply all the bits you need new.
http://alans-electrics.alanlowe.co.uk/home
Post by: BigAl (Alan) on March 29, 2018, 02:37:15 PM
I have all of the 6.3mm OE square latched connectors (and some un-latched) in stock, if you do require a pair/set, then please PM me.
Normally I do not sell individual parts, but for members on this site & VJMC I do make the exception.
Alan
Post by: ogri211 on March 29, 2018, 08:47:37 PM
Thanks for the input if the the connector is a standard 6.3 6 connector plug I think I may have one I am away from home just now working I should be able to sort something out.
Post by: ogri211 on March 30, 2018, 07:43:24 PM
Ive contacted Steve at 400four parts and he is going to sell me one with a foot of cable so I will be able to solder and heat shrink it onto my original wiring.
