SOHC.co.uk Forums => Project Board => Topic started by: Crispy on March 31, 2018, 04:39:09 PM
Title: 750 K1 project
Post by: Crispy on March 31, 2018, 04:39:09 PM
I acquired my valley green K1 a couple of months ago, its a US import in need of some attention. I have just started to spend some time on it as youve probably gathered from some of the posts i've already made. I'm really pleased to have joined this group because i have already received a lot of help and advice and found loads more information through reading other members posts and projects. Thanks.. its much appreciated.
The bike is now stripped and parts sorted,labelled and stored until ready to be dealt with. I thought i would make a start on the motor and I now have it cleaned and on a stand (thanks Julie!) but have been brought to a standstill on that front by the 3 breather cover screws on the rocker cover. All are seized solid. JIS impact driver wouldnt loosen them nor heat or penetrating oil, drilling the heads off made no difference, the cover still wouldnt come off.
I have after a week or so got the breather cover off and two of the screws out completely but one stubborn bu#8er will not come out and is holding the rocker cover on with it!...I will get it out eventually! :)
I have the forks stripped and ready to go for hard chroming, the seat is covered and just needs a couple of finishing touches (done while waiting for the penetrating oil to work its magic!).. Im really enjoying this!
Title: Re: 750 K1 project
Post by: Crispy on April 02, 2018, 11:12:13 AM
I've eventually managed to remove the rocker cover without causing any damage, and am about to start dismantling the camshaft and cylinder head, keeping my fingers crossed that I won't find anymore stubborn fasteners. I have the Honda workshop manual and have read a lot of threads but does anybody have any advice before I take the plunge dive in?  :-\
Cheers!
Post by: Nurse Julie on April 02, 2018, 12:09:01 PM
Slow, steady, methodical.
Post by: Spitfire on April 02, 2018, 12:17:28 PM
Not an expert at all, but I usually lay out the engine parts that I remove in the order that I remove them, so that they go back in the same place, before using any violence check thoroughly for hidden bolts, keep everything clean, you do not want even the tiniest of debris in those oilways. Take photos of stuff before you take it apart, pay paricular attention to cable and wiring runs, use plastic bags to keep parts in groups with bolts washers etc. Be patient and have fun
Post by: Crispy on April 02, 2018, 10:00:06 PM
Cheers guys, all tips and advice welcome!
Today I've managed to get the motor top end stripped down, no major traumas and without "using any violence" lol Dennis ! Plus I haven't damaged anything..as far as i know! ::)..  I need to take a few measurements now..pistons,rings bores etc, that will have to wait a while now..work does get in the way!
Ps. I've read threads re the cylinder studs but I didn't realise how slender and flexible they were until I've seen them today in the flesh for the first time, they don't inspire confidence do they? Do I take them out or not hmmm?  :-\
Post by: Crispy on April 09, 2018, 02:41:46 PM
Guys, Should these clutch release parts look Look this or are they worn?
Post by: Trigger on April 09, 2018, 02:44:38 PM
They look like that so that the ball bearings slide in and out easy. On reassemble, grease the parts and change the balls if rusty or not smooth  ;)
Post by: Crispy on April 09, 2018, 02:49:41 PM
Thanks very much Trigger, ... My balls aren't rusty  ::) so should be ok with a bit of grease!  ;D
Post by: Trigger on April 09, 2018, 02:50:03 PM
Those head studs look good, leave them alone  ;) ;)
Post by: Trigger on April 09, 2018, 03:05:12 PM
I wish I had customers engines in for rebuilds that looked that good  ::)
Looks like it has never been apart before, what type of oil jets are in the head ? It should be the pepper pot ones  ;)
Post by: Crispy on April 09, 2018, 03:46:19 PM
Now you're asking! I'll have to find them first. Will look shortly! I don't think it has been apart before....it's looking better than I'd hoped although I need to measure everything yet and see how much wear there is.
Post by: paul G on April 09, 2018, 03:48:55 PM
Trigger,
               You might want to explaine the pepper pot as they do look more like a salt pot on the top  ;)
Post by: Crispy on April 09, 2018, 03:56:11 PM
This one?  Do they need to come out?
Post by: Nurse Julie on April 09, 2018, 04:40:12 PM
Look like salt pot on the top side but pepper pot on the underside if yours are these type. Like this
[attachimg=1]
Yes, need to come out to be cleaned thoroughly. It can be a  very difficult job to get them out, one usually comes out easier than the other. Sometimes have to almost wreck them to get them out and then re engineer to make good. No longer available OEM or pattern.
Post by: Crispy on April 09, 2018, 04:49:08 PM
Et Voila!  :). Good job you guys know what's What ! You had me worried then with talk of 're-engineering'  :o These two have come out quite easily...which is more than I can say for some the fasteners so far! Can't budge the exhaust stub screws !
Post by: Nurse Julie on April 09, 2018, 04:53:29 PM
Et Voila!  :). Good job you guys know what's What ! These two have come out quite easily...which is more than I can say for some the fasteners so far! Can't budge the exhaust stub screws !
Blimey, you are a very lucky chap. Graham would faint with shock if he had them come out that easy but, like he said previously, your engine looks a million dollars compared to some of the ones we get through here  :'( :'( :'(
Post by: Crispy on April 09, 2018, 05:03:39 PM
Yes I'm beginning to realise that it's not bad after seeing some of the project threads...still it's a big  but enjoyable learning curve for me ....and I've learned loads today...🙌
Post by: Bryanj on April 09, 2018, 05:29:29 PM
Big thing is all oilways scrupulously clean along with gasket surfaces, a tiny amount of gasket material in an oilway will wreck the top end
Post by: Trigger on April 09, 2018, 05:43:02 PM
How the hell did you get those out without grabbing hold of the nipple ?  Or have you flattened the nipple ?
 I have made so many special tools to get those out.
Post by: Crispy on April 09, 2018, 05:55:40 PM
Cheers Bryanj
After reading your post I've just spent a few minutes blowing air down all the holes in the cylinder head and seeing where it comes out ...to give me an idea of where the oil ways run...and to make sure they're clear. It is difficult to keep everything clean though, I power washed the motor before I started stripping it down but there's still dirt everywhere. I can now understand why some of you have separate clean and dirty workshops.
Post by: Crispy on April 09, 2018, 06:25:08 PM
I think my nipples are ok! 😬
Although I did grab hold of them with a pair of long nose pliers! I didn't put too much pressure on them..gave them a waggle and out they popped!
Post by: Crispy on April 09, 2018, 06:45:22 PM
Finished my seat off today with the logo and strap, pleased with how that turned out and also butchered a spare socket to make a valve removal tool which worked really well. I know it's not a big deal but it was very satisfying to get them all out with it!  ::)
Post by: Crispy on April 09, 2018, 07:16:25 PM
Got another question...having removed the valves, there are only 4 valve stem seals ..on the inlet valves ..although the exploded parts diagram shows them on both inlet and exhaust.. Is this because it's an earlyish motor?
Post by: Nurse Julie on April 09, 2018, 07:27:24 PM
Yes, the early ones don't have exhaust valve seals.
Post by: Trigger on April 09, 2018, 07:34:08 PM
Those are in perfect shape, more evidence that that motor has never been apart before  ;) To clean the jets, soak in thinners for a couple of days and dig with a thin bit of wire (from a wire brush) before blowing out with a airline.
Post by: Crispy on April 09, 2018, 08:47:30 PM
Post by: Crispy on April 15, 2018, 10:09:39 AM
I've measured my cylinders, pistons and ring gaps, (see pic)  Measurements seem to be only just within tolerance, out of round and taper seem ok. What do you think folks? ...will I be ok using the cylinders and Pistons as they are Just replacing the rings ?
Limit for cylinders is rebore if diameter is greater 61.1mm
Limit for piston is replace if diameter is less than 60.85mm
My measurements seem to be very close to these limits although they are within them.  :-\
Post by: Trigger on April 15, 2018, 10:17:10 AM
By your measuring, it looks like piston 2,3,4 won't fit the bore as the pistons are bigger  ;)
Post by: Crispy on April 15, 2018, 10:29:29 AM
🙄....damn!! I'll do them again!! 😂
Post by: Crispy on April 15, 2018, 10:45:43 AM
Ok here's another attempt..these are the averages of several readings....it's a long time since I've done any maths!! 😂
Just realised that the pistons are measured at the skirt...mine are very tight in  the bore of the cylinder at the top!
Post by: Trigger on April 15, 2018, 12:21:12 PM
That looks better. The skirts are very tight on a Honda.
Is there any lip at the top of the bores, pics please  ;)
Post by: Crispy on April 15, 2018, 01:13:17 PM
Yes I can feel a lip.
Post by: Trigger on April 15, 2018, 01:25:05 PM
OK, they need to be honed out until the lip is visible no more. Then you can get a true measurement  ;)
I know what all the books say to the max spec but, when this engine was new, the piston to bore clearance was tight and when I mean tight, less than 1 thou.
Post by: Crispy on April 15, 2018, 02:01:30 PM
Cheers Trigger, I'll see about getting that done ...👍
Post by: Crispy on April 16, 2018, 09:01:07 PM
Checked the valves over tonight..looks like they and the guides will need replacing they failed on both the valve guide clearance and vertical run out measurements...by a large margin! doh! 😕  On a more positive note the springs are ok! 😊
Post by: Nurse Julie on April 16, 2018, 09:06:12 PM
Loving your upside down pics, is it a Derbyshire thing? 😀😀😀
Post by: Crispy on April 16, 2018, 09:10:52 PM
Haha! Don't know why they appear upside down! They turn the right way up when you view them ! 🤔😂
Post by: Trigger on April 16, 2018, 09:12:48 PM
The valve face is pitted, this is down to the valve clearance being too tight. These will need re facing  ;)
Post by: Crispy on April 16, 2018, 09:28:02 PM
u
The valve seats look ok tho! 😬
Post by: Trigger on April 16, 2018, 10:07:34 PM
They will clean up but, if you have new valve guides fitted. The head needs to be about 300c in a oven and the guides need to be frozen to make fitting easy. The heat distorts the head a little so, a head skim and valve seats re ground. Not Cut  ;)
Post by: Crispy on April 17, 2018, 08:12:25 AM
I've seen threads re pre honed guides on the US site... What's the score with these..do these do away with the need for reaming after fitting?  opinion seems to be divided?
Post by: Trigger on April 17, 2018, 08:39:22 AM
There is plug and play valve guilds on the market for modern heads. They come as a set, valves and guilds, even today there are valves on the market that are Teflon coated so, you can't even lap them in. This is all apart of the throwaway society and making engineers in to fitters.
On these old girls, you should use the upgraded valve guides, that have oil seals on all. One of the best I have found are sets from Yamiya. These still need to be reamed with a Honda tool to spec.
Post by: Crispy on April 17, 2018, 06:46:51 PM
Ok 👍  Thanks for that...ill probably end up farming that out! I've never reamed anything and probably not a good idea to start now! 😬
Post by: Trigger on April 17, 2018, 07:47:45 PM
Just make sure that they know about old Honda's and have the right tooling. I spend half my day correcting other engineers work  >:( And if they mention that they do brit bikes, RUN  ;)
Post by: Crispy on April 18, 2018, 07:11:20 PM
Post by: Crispy on May 07, 2018, 05:53:10 PM
Damn!! Took the sump off  today and found these two pieces lying there...don't know where they've come from yet but it's a bit of a dampener on such a nice day!
Post by: Nurse Julie on May 07, 2018, 06:04:36 PM
Don't panic yet, they look like they are pieces of the internal casings.....i could be wrong of course but they look mighty familiar. As you strip the engine fully, just keep your eyes open for some bits missing around the mouldings on the casings.
Post by: Crispy on May 07, 2018, 06:15:00 PM
I have the engine in the stand, would you take it out and turn it upside down to split it or just carry on with it in the stand?
Post by: Crispy on May 07, 2018, 06:52:33 PM
Ok belay that last question..its out and upside down! 🙄
Post by: Crispy on May 07, 2018, 07:11:59 PM
Found the damaged area..right beside the primary chain tensioner. This critical?
Post by: Nurse Julie on May 07, 2018, 07:19:21 PM
I will ask Trig if he advises repairing or just leaving, I will report back.
Post by: Crispy on May 07, 2018, 07:29:25 PM
Thanks Julie! 👍
Post by: Nurse Julie on May 07, 2018, 08:06:33 PM
Thanks Julie! 👍
Trig says he would leave as is. It most probably would have been damaged by the cam chain flapping around at some stage in the engines life.
Post by: K2-K6 on May 07, 2018, 08:30:02 PM
If it's been apart before then it may have had the crank rotated with the cam not in place and the chain bunched down round the crank.
It doesn't look structural,  but I think they use things like that for "windage" to get oil to separate from the crank at high rpm and force it to drop back into the sump rather than getting a mass of oil rotating with the crank assembly.
Post by: Crispy on May 07, 2018, 08:47:31 PM
Thanks folks..👍
Post by: Trigger on May 07, 2018, 09:10:58 PM
Normal on a 750  ;)
Post by: Crispy on May 07, 2018, 09:35:27 PM
Phew was worried for a while.....👍
Post by: Trigger on May 07, 2018, 10:54:50 PM
When fitting a new cam chain, always use the upgraded DID  ;)
Post by: Crispy on May 08, 2018, 11:33:26 AM
👍 Will do..thanks.
Going to check the main bearings for wear next...for the K1 is the red plastigauge in the range 0.025-0.175mm the one to get? Just double checking, 🤔
Post by: Tomb on May 09, 2018, 01:42:05 PM
Hahahaha yep I know this feeling, I have the "special" reamer, and make my own guides, and do Brit bikes (run!!) but also do old Hondas, Yamahas, Suzukis. Back when I did engineering work for folk I'd get a lot of work repairing local bike shops "engineering work".
Old Brit bike work on guides usually consisted of making bigger outside diameter guides as they had come loose in the head and worn the head, or knurling standard guides. I'd always make them a really tight fit to prevent it happening again, this would usually end up nipping the guide making the stem tight and reaming needed.
Post by: Crispy on May 14, 2018, 07:07:12 PM
Not checked my main bearings yet..still waiting for some plastigauge to arrive but judging by the wear and tear so far I'm expecting to have to put new ones in..so have been getting my head around the method of selecting the bearings this afternoon...not straightforward..like go out and buy a 6304 bearing is it?  Think I've Sussed  it....written them down below...any tips on where is the best place to get them if needed, also need to get full gasket , oil seals and o ring set?
Ps the upside down picture thing is something to do with my iPad, only occurs with pics taken with that...nobody else suffer from this?
Post by: Crispy on May 15, 2018, 07:32:28 AM
Just realised David Silvers has the bearings..thought they would be harder to find 🙄
Post by: Crispy on May 20, 2018, 05:17:24 PM
Measured the bearing clearances today...I'm thinking that these bearings will be ok  to re-use....I get a clearance of 0.050mm and the limit according to the manual is 0.080mm....However the manual also states that the standard clearance should be 0.02 to 0 046mm. Should I replace them anyway?
Post by: Trigger on May 20, 2018, 07:05:14 PM
To get that reading, have you torqued the crank up.
Bearings can be a bit funny, some of the gearbox bearings are under licence to Honda only.
Post by: Crispy on May 20, 2018, 07:18:19 PM
Yes..torqued it up as per the manual!
Post by: Trigger on May 20, 2018, 07:24:06 PM
Well, your plasti strip is a lot cleaner than mine  ;D ;D
Post by: Crispy on May 20, 2018, 07:29:05 PM
Well I've only used it once!... Bet yours has been put to more frequent use!
Post by: Trigger on May 20, 2018, 07:32:30 PM
I would go with those shells. Is the oil pump apart yet ? If the oil pump is at full pressure, the shells are fine.
Post by: Crispy on May 20, 2018, 07:39:47 PM
Cool ...No..I haven't touched the pump yet 😬  Will do at some point though !
I'll also repeat the plastigauge measurements a couple more times just to see if I can repeat the same results.
Post by: Crispy on June 03, 2018, 08:14:32 PM
Engine cases painted and cured, I can now begin to re assemble the engine.  After reading older threads I'm thinking I will get the Vesrah gasket set and Honda head gasket, unless anyone has any other advice.? I am also replacing the primary and cam chains, again any advice re primary chains ? Getting the upgraded did chain ....part number ....219FTH 94LE ..which I've just spotted on another recent thread... Cheers Trigger 👍
Post by: Trigger on June 03, 2018, 09:03:13 PM
Looks nice, what paint was used ? Use the STD primary chains. Vesrah are the best available.  Not sure if anyone in the UK does the upgraded cam chains, seems to be a lot of old stock ones floating about. If you get stuck for one, I can supply you one  ;)
Post by: Crispy on June 03, 2018, 10:20:12 PM
Cheers Trigger,
Used Simoniz VHT31C engine enamel, may be in touch re cam chain! 👍
Post by: Crispy on June 08, 2018, 06:51:09 PM
Got some nice shiny fork bits back from Philpotts today! 😊 Here are a few before and after pics..
Post by: JamesH on June 08, 2018, 07:13:03 PM
Lovely work from Philpotts there..
Post by: Nurse Julie on June 08, 2018, 07:45:23 PM
Lovely shiney blingy bits there. Very nice. Did they polish the fork lowers you?
Post by: Crispy on June 08, 2018, 08:00:04 PM
Yes, although they farm it out to someone else. It's the first time I've had anything polished I usually do it myself but they've done a much better job than I could have. One of the fork lowers had some deep marks in which although they haven't come out fully are nowhere near as bad.
Post by: Crispy on June 08, 2018, 08:02:22 PM
I agree, I was concerned about the depth of the corrosion but they reassured me, apparently in all the years they've been rechroming pitted forks they have only had a handful that were beyond repair.
The fork top nuts have come out really well, they were really chewed up and marked...look new now!
Post by: Crispy on July 16, 2018, 10:03:53 AM
after a bit of a delay in things due to unforeseen circumstances,  I have got my cam and primary chains ,gaskets and seals sorted...I'm probably using the existing bearings as they seem OK...im just unsure about the chain tensioners. Should I just replace them as a matter of course?  The wheels and guide seem to be in OK condition but they are 47 years old??
Post by: Nurse Julie on July 16, 2018, 10:13:04 AM
They may look ok but the rubber bits will probably be hard and brittle so best to change them as you are there.
Post by: Crispy on July 16, 2018, 10:23:20 AM
Yes..I suppose I answered my own question there...thanks for the reply 👍
Post by: Crispy on July 19, 2018, 10:08:40 PM
Made a start tonight on reassembling the motor...got the crank,mainshaft and final drive assembled in the top case. It is probably going to be several months before it (hopefully) runs..i am using graphogen and engine oil as lubricants? It's a great feeling when parts start going back together!...so far anyway!  :)
Post by: Crispy on July 21, 2018, 08:59:17 PM
Today I got most of the engine internals fitted into the crankcases, I'm now waiting for a few o rings to arrive before closing the cases up..what are your thoughts folks on the oil catch tray that directs oil onto the drive sprocket? ...I've read that it can be quite messy...Can it be left out?
Post by: Green1 on July 21, 2018, 09:17:18 PM
Mines still there turned down to its minimum.
It does get oil on the back wheel but I can live with that as I do give the bike a bit of stick. In the 5 years and almost ten thousand miles I have never needed to adjust the chain  :)
Oil on the rear wheel is a good thing in my eyes it keeps the chrome nice
By the time the rear wheel is black the bike needs cleaning anyway.
Post by: Trigger on July 21, 2018, 09:46:32 PM
I always fit the oil plate and cap off the oil outlet with a O'ring  ;)
Post by: Green1 on July 21, 2018, 09:53:20 PM
Why do that Graham there not your bikes to clean in the future.
Think of all those pennies you could have saved.  ;D ;D
Post by: Crispy on July 22, 2018, 07:02:35 AM
Thanks guys...fitted it is then 👍
Post by: Crispy on July 22, 2018, 03:28:52 PM
I'm about to fit the cases together...got new o ring on the gallery feed to front of cases and 2 locating dowels in place on 1 on each side, new primary chain tensioner in,loctited and torqued..all surfaces cleaned, using Honda bond....any advice ..tips...warnings before I go for it?  :-\
Post by: Nurse Julie on July 22, 2018, 03:33:18 PM
Maybe a dry run first, just to check it is all going to go together ok.
Post by: Trigger on July 22, 2018, 03:35:43 PM
You need to put the crank seal on first  ;)
And final drive seal  ;) I will keep looking  ;D ;D
Post by: Crispy on July 22, 2018, 03:38:21 PM
Great...good job I asked! Thanks 👍.....I need to get out of the garage for a while tho..I used lacquer thinners to clean all the surfaces..I'm getting a bit high! 😂
Post by: Trigger on July 22, 2018, 03:50:00 PM
Can't see if you have the roll pin fitted and are all the half rings in ?
Have you done a dry run, to make sure all gears select .
Post by: Crispy on July 22, 2018, 04:44:08 PM
Yes..I have the three half rings and the roll pin that holds the kickstart shaft...crank seal and final drive oil seals are in now...trial fitting ok ..but I'll do it again and try the gear shift this time! 🙄
Post by: Crispy on July 22, 2018, 04:59:58 PM
Woohoo!....I can get 5 gears 😀
Post by: Nurse Julie on July 22, 2018, 05:05:21 PM
Post by: Crispy on July 22, 2018, 06:11:58 PM
 Bottom half back together, with Julie & Triggers timely help and advice, 🙌 thanks so much...having the knowledge of you guys available is so invaluable...got to get the top end sorted now but I'm pleased to get this bit done before I forgot where everything went! 💪
Post by: paul G on July 22, 2018, 06:58:39 PM
Lookin good. Painting my cases tomorrow  :)
Post by: Rob62 on July 22, 2018, 09:26:24 PM
Yeah looks really nice... its better if you can split the cases for painting. Mine was painted without splitting, as the motor internals seemed ok so a shame to split, but the painting looks betterr on yours.
Post by: Crispy on July 22, 2018, 10:11:26 PM
Cheers Guys, it's also easier to get it in the oven for curing 😉
Post by: Trigger on July 22, 2018, 10:27:21 PM
Looks like everyone is building K1's. I will have this one finished by the end of the week  ;)
Post by: Crispy on July 22, 2018, 10:58:32 PM
Nice one..just noticed on your lower case, the large round section has a securing clamp on it which mine doesn't have. It has the post for the bolt but it is undrilled. I assume some have it and others don't ?
Post by: Trigger on July 22, 2018, 11:04:51 PM
That's because it is a it is a early K1 and yours is later  ;) Yours also has M6 flanged engine bolts and the one i am doing is the non flanged type. The oil bungs on the early's have a 17 AF and all later units were fitted with 14 AF.
Post by: Crispy on July 23, 2018, 07:39:23 AM
Cheers Trigger...I must be turning into some sort of anorak! ...I find all these little differences/changes quite fascinating!  😬
Post by: Trigger on July 23, 2018, 09:19:38 AM
I would not say that it is being a anorak, it is just knowing the history of your bike.
The K1 was fitted with two different types of crank cases fitted. The early K1's had the crank cases used from the K0's  ( with slight changes in the castings ) and moved on to the later cases, which were used on some of the K2's.
The engine evolved over the years with 3 different types of oil pumps, 3 different clutch baskets, 2 different selector drums and so on. I don't need to see a engine numbers to know what year it is  :o Or if it has the wrong barrels or head fitted for that year. I have never found anyone that has wrote a book on all the correct detailing of the CB750K engines.
Post by: paul G on July 23, 2018, 01:19:47 PM
Maybe it's time you started Graham ;)
Post by: Trigger on July 23, 2018, 11:22:34 PM
Books Paul, i can't even be bothered to read one, never mind write one. Never seem to have time with members asking questions and looking for parts all day  ;D ;D ;D
Post by: Crispy on July 24, 2018, 10:02:43 PM
You can't beat knowledge gained by actually working on these engines over a lifetime....or practical experience in any job...and a good job for us that you and others are willing to share it! 👍
Post by: paul G on July 24, 2018, 10:31:00 PM
Who me  ;D ;D ;)
Post by: Nurse Julie on July 24, 2018, 10:37:03 PM
Who me  ;D ;D ;)
Trigs not pointing any fingers Paul but..........👉 👉 👉 👉 👉😊😊😊
Post by: Crispy on July 15, 2019, 06:13:42 PM
I've not posted anything on this thread for some time, things have progressed slowly but my motor , now Trigger has sorted the top end out for me,  is now ready to be fitted into the frame. Wheels are done just waiting for tyres, zinc plating done, chrome plating done, powder coating done. Left to do is paintwork, find a few parts that were missing or beyond repair and begin saving up for a full exhaust system, oh and probably replace most of the rubber parts that are rock hard. Things are beginning to get exciting, should have a rolling chassis soon!
Post by: Nurse Julie on July 15, 2019, 06:32:18 PM
Looking fantastic Mick.
Post by: Rozabikes Tim on July 15, 2019, 06:46:57 PM
That's impressive mate, well done. My parts that I collected from T and J with yours on the same day are still on my bench untouched (but wrapped carefully to stop dust and dirt Trig!!). You have too much time on your hands!! :P
Post by: Laverda Dave on July 15, 2019, 07:45:52 PM
Looking fantastic Mick. Real engine bling going on there!
I must retrieve my 750 motor from its den in Glasgow and get it over to Trigger for his magic touch👍.
Post by: royhall on July 15, 2019, 07:49:25 PM
Don't they look great when everything is painted and polished. Tends to hide the amount of effort it takes to get to that point though. Anyone that hasn't done it before is usually amazed at the cost and hours it takes. Many just become adandoned projects. Top job there, looking forward to seeing the rest of the bike.
Sent from my Pixel 3a XL using Tapatalk
Post by: Crispy on July 15, 2019, 08:49:15 PM
Thanks all for the kind words, wouldn't have got this far without the Help &  encouragement of the people on this forum  :)
Post by: Crispy on July 15, 2019, 08:52:52 PM
Thanks ! I can definitely understand why some become abandoned projects, unless as you say you've done it before then the time,effort and cost can come as a bit of a shock!
Post by: Green1 on July 15, 2019, 08:55:21 PM
Looking smart. I would love to spend more time on mine
Don't go green on the paintwork its to common and overrated  ;D
Post by: Crispy on August 11, 2019, 08:36:34 AM
Got the motor in to the frame now with my wife's help! Wheels are on so I can move it around as things are a bit tight now in my garage. The eagle eyed amongst you may spot that I have the front axle nut on the wrong way round in the picture (now corrected). The clocks were refurbished for me by Peter Kent  and Graham (Trigger) sorted out the motors top end. Thanks for all the help & advice so far, I'm pretty sure I'll be asking a few more questions before its finished, still a long way to go but it's looking like a motorcycle again now!
Post by: Crispy on August 11, 2019, 08:41:09 AM
thanks, I'm not sure what colour I'll do the paintwork, at the moment I'm thinking to stay with Valley Green  but I'm tempted to go Candy Gold, I may just have to get another 750 so I can have one of each! :)
Post by: Nurse Julie on August 11, 2019, 09:01:30 AM
Great progress Mick.
Post by: Laverda Dave on August 11, 2019, 12:10:26 PM
Looking fantastic Mick, not long to go before it's on the road.
Post by: JamesH on August 11, 2019, 12:44:48 PM
Great progress - looking awesome. Keep the pics coming...
Post by: paul G on August 12, 2019, 08:09:24 AM
Coming along nicely Mick  :D
Post by: Crispy on August 12, 2019, 10:44:34 AM
Thanks all, I'm not expecting to get it on the road soon though, still missing quite a few parts  :o. I've  set myself a target of getting it ready for the next Crich show, if i manage it before then that will be a bonus.
I'm sorting the wiring out at the moment, trying to get it all in place and working while the frame is relatively bare, I'm not sure about the rectifier it looks a bit battered and the rubber surround to it has perished but hey ho! overcoming these little problems is one of the joys of restoring these old bikes. :)
Next problem to sort is an oil tank leaking from the base of one of the hose connections where it enters the tank, I'm going to try and get it brazed I think, anyone else had similar leak to sort?
Post by: Trigger on August 12, 2019, 09:16:16 PM
These were brazed from the factory. You will have to get all the paint off and make sure the tank is free from rust on the inside.
Post by: Crispy on August 25, 2019, 02:12:40 PM
Made a bit more progress today, got the Carburettors reassembled, everything seemed to go back together ok, good job I took loads of pics and notes!  :). here's before and after pics.
Post by: Nurse Julie on August 25, 2019, 06:01:14 PM
They have come up fantastic Mick, great job 👍👍👍
Post by: Andrew-S on August 25, 2019, 06:08:34 PM
Carbs look great, it may be one of the jobs I'll have to tackle on my K1.
Post by: Crispy on September 09, 2019, 07:52:49 AM
Pleased to report that I've had the oil tank repaired, I've painted it and it's now fitted to the bike along with whatever else I have that is ready to bolt on. I need to sort a brake out next as the bike is getting difficult to stop when I roll it back into the garage from my hill of a drive! :o Can anyone enlighten me as to how the oil tank works? In particular what does the pipe connected to the crank case do? Is it just a breather?   Thanks!  :)
Post by: SumpMagnet on September 09, 2019, 06:07:32 PM
Looking much shinier than my efforts :)
Not sure about the K1...but my F2 had a complex arrangement of pipes coming off the crankcase, through a catch tank bolted to the bottom of the battery box.
It wasn't connected to teh oil tank...the oil tank had a breather/overflow pipe running from the top back side of teh filler cap...straight down to the deck.
Now....that may not be correct...but it's how mine was when I got it
Post by: K2-K6 on September 09, 2019, 07:26:17 PM
The F2 came in the era of emmisions and trying to avoid output to atmosphere.  They effectively collect any oil suspended in air (smoke to most of us)  and seperate it at the air filter contraption to burn any contaminant by drawing in through intakes.
The early tanks vent to air from the top generally,  they have a built in air oil separator inside the tank that splits oil vapour to drip back into oil supply,  with air going out to ground.  This is from description in KO manual,  you'd have to look at later manuals to see your K model.
They have to vent both tank and crankcase,  ultimately to atmosphere, to prevent overpressure in engine.
Sealed completely, it'll try to push oil out of oil seals etc.  Also interferes with dry sump system on 750 as you don't need either vacuum or pressure exerting against oil pump operation.
Post by: Crispy on September 09, 2019, 10:28:51 PM
Thanks, I understand what it's doing now, mine has the built in separator inside the tank, which as you say vents to ground from the top, the crankcase connects to the bottom.
Post by: Green1 on September 12, 2019, 09:44:19 PM
looking great Mick fancy having a crack at mine when your done?   :D
Post by: Crispy on September 13, 2019, 07:13:32 AM
Cheers Mick, I'm pleased with how it looks but the acid test will be when I come to eventually try and start it it!  :o I might have to work on other peoples bikes at some point! I don't think I could afford another one!  ;D
Post by: Crispy on September 13, 2019, 03:59:41 PM
Well having connected the oil tank up I started to put some oil in It Only to find it pouring out onto the bike and floor! Damn! On removing it and having a look,  I found that the rear oil hose had broken at the tank connection. I suppose better now than later when it's finished!  I know These are not cheap!  :-\ don't suppose I should trust the one that's left!
Post by: Green1 on September 13, 2019, 04:28:31 PM
I would risk keeping the other hose and then regret it as having one new one old would bug me.
Post by: Crispy on February 24, 2020, 11:34:21 PM
Well, after a bit of a break, OK about 3 months :o where did that go? I have managed to replace the damaged oil tank hose, fill with oil and get it circulating up to the camshaft (although it's not squirting everywhere, more like flowing copiously) using the kickstart. I have now also collected replacement side panels, lamp holders and headlamp shell and will be taking them with the tank to the paint shop in the next week. Colour undecided as yet but do like the Candy Blue Green. Still loads to do and a few more parts to find but its getting more complete every day.  :)
Post by: paul G on February 25, 2020, 07:47:11 AM
Coming along Mick.
I loved the Candy Blue Green but if you are staying original it's not a UK K1 color which is why I went the Red.
Post by: Trigger on February 25, 2020, 09:40:03 AM
You will not get much oil pressure by using the kick start. When the engine is turning over at 1000 rpm without the rockers in place, the oil pressure pushes the jets out ;)
Post by: Crispy on February 25, 2020, 09:53:24 AM
Coming along Mick.
Love the red as well Paul,  I keep changing my mind which way to go, mine is a US import and its original colour is Valley Green, which I also like :-\
Post by: Crispy on February 25, 2020, 09:56:11 AM
Graham,
I think the only thing raised while using the kickstart was my blood pressure but I was relieved to see some oil make an appearance through the tappet covers!  :)
Post by: Crispy on February 25, 2020, 10:04:29 AM
Coming along Mick.
I'll have to decide soon because, as the forecast snow hasn't arrived I'm just about to set off for the paint shop!  ::)
Post by: Andrew-S on February 25, 2020, 10:17:15 AM
...........will be taking them with the tank to the paint shop in the next week. Colour undecided as yet but do like the Candy Blue Green. Still loads to do and a few more parts to find but its getting more complete every day.  :)
Coming along nicely and I'm enjoying keeping up with this thread - what's the timeline for completion?
There's a school of thought that promotes originality, but have to say that if my K1 was any other colour than Candy Ruby Red (or Gold) I'm pretty sure I would have chosen one of those colours despite the 'dilemma' losing some originality, lucky I didn't have to choose.
At the end of the day it's your bike, so any colour you wish.
Post by: Crispy on February 25, 2020, 04:41:11 PM
Andrew,
I'm hoping to have it finished in time for Crich this year,  I'm enjoying keeping up with your build as well, great job!  I have dropped everything off now at the painters and have plumped for the Candy Blue Green, whatever the colour its going to be an improvement on the starting point!
Post by: Andrew-S on February 27, 2020, 09:28:32 AM
Andrew,
Looking forward to seeing photos of the finished job and hope you've got it ready for Crich. My K1 will be, but I won't - I promised my wife I wouldn't jump straight onto my bikes and start riding on 2 July. Makes sense, I suppose.....
Post by: MrDavo on February 27, 2020, 03:36:45 PM
Quote
I quite like Valley Green, in my eyes a candy version of British Racing Green, and the colour of the first CB750 I saw in the flesh, but noone ever chooses Candy Poo Brown.
By the way when I rebuilt my CB750 K1 engine, I kicked and kicked, and even tried the starter in desperation but not one drop of oil did I see until I took advice from this board and primed the oil pump with half a tub of Vaseline!
Post by: Crispy on February 28, 2020, 07:25:33 AM
I was really expecting to have to do the Vaseline thing but priming the pump with oil seems to have worked out ok. I submerged the pump in oil and operated it by hand until the air bubbles stopped appearing then fitted it to the engine while it was on the bench then fitted the engine in to the bike. It then sat there for 3 months or so until I found a replacement oil hose  so I was mildly surprised to say the least when oil appeared at the camshaft!  :)
Post by: Crispy on September 20, 2020, 07:21:21 PM
Well after what must be the longest wait for a paint job here's an update on this stop / start project.
I dropped my tank etc off for painting in Feb, just before lockdown and got it all back last week.I couldn't resist fitting it temporarily just to see how it looked. It is candy blue/ green although it looks more like blue in the photo.
The front end is finished, brakes sorted, all electrics work, just need to fit the carbs , find an airbox lower half ,order the exhaust system then fire it up, hopefully! ....Maybe another 6 months the way things have been going!  ::)
Post by: Nurse Julie on September 20, 2020, 07:52:55 PM
Wow, That is looking fantastic Mick, you can't rush a good thing. Just one little observation, your Honda wings on the side panels fitted to the bike, are flying backwards but in the other photo of just the side panels, they are on the correct way 🤔🤔🤔
Post by: Crispy on September 20, 2020, 07:56:30 PM
Cheers Julie,
Yes I hadn't secured the Honda wings permanently in either of the pictures, they are fixed now though and facing the correct way.  ;)
Post by: Andrew-S on September 20, 2020, 09:42:26 PM
Looking great Mick - there's a NOS set of HM300s on eBay, not cheap though: https://www.ebay.co.uk/itm/Genuine-Honda-OEM-Exhaust-Mufflers-HM300-1969-1971-CB750-FOUR/293668083784?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 (https://www.ebay.co.uk/itm/Genuine-Honda-OEM-Exhaust-Mufflers-HM300-1969-1971-CB750-FOUR/293668083784?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649)
Post by: Crispy on September 21, 2020, 07:03:39 AM
Cheers Andrew, £3500  :o, if only money was no object! I'm going to have to settle for silvers or cmsnl, even those prices are making my eyes water!   ;D
Post by: Rozabikes Tim on September 21, 2020, 08:02:36 AM
Looking good. Love that colour scheme, one of the best. Local painter???
Post by: Crispy on September 21, 2020, 06:56:34 PM
Cheers Tim, it looks great in the flesh, photos seem to change the tone a bit. Dream Machine, Long Eaton painted it. Done a good job .  ;)
Post by: Rozabikes Tim on September 21, 2020, 09:16:31 PM
Just down the road then!
Post by: Crispy on October 15, 2021, 04:54:00 PM
After a year long wait for a set of HM300 pipes this K1 is now  almost finished, just a few finishing touches needed. Much to my surprise and delight It fired up straight away, and all seems good, it sounds terrific, much throatier than my old K2.  Just need to register it with DVLA now and get it on the road.
Post by: Sesman on October 15, 2021, 05:13:42 PM
Grea effort. Looks absolutely pristine.
Post by: Nurse Julie on October 15, 2021, 05:29:36 PM
That really does look lovely Mick, well done.
Post by: McCabe-Thiele (Ted) on October 15, 2021, 05:33:23 PM
Brilliant looking build.
Post by: heli_madken on October 15, 2021, 05:56:34 PM
Now that is absolutely beautiful, I could die happy if I had that bike  :)
Post by: Rozabikes Tim on October 15, 2021, 06:16:32 PM
That's fantastic well done!!
Post by: Crispy on October 15, 2021, 06:22:59 PM
Thanks for the comments everyone!  I couldn't have done it without the help of this forum and its members you have been a mine of information, and practical assistance, thanks.
Post by: MrDavo on October 15, 2021, 06:25:05 PM
A lovely job Mick, my K1 came in Candy Blue Green, but when the paint had to be redone I went for Candy Ruby Red after much heart searching. Having had both, the red (done by Menno) was splendid but the blue is a more interesting colour, there's something a bit Japanese about it.
Now go and cut that cable tie holding the clutch cable to the frame tube.
Post by: Crispy on October 15, 2021, 06:30:22 PM
Haha! It's a reusable tie I put on temporarily, I don't want to cut it I'll replace it with an ordinary one. I also need to connect the carb drain tubes up before anyone mentions them!  :)
Post by: Spitfire on October 15, 2021, 06:51:47 PM
That really is a thing of beauty.
Post by: Andrew-S on October 15, 2021, 07:57:07 PM
Stunning bike, I've followed your updates and it's a real credit to all your efforts.
Cheers,
Andrew
Post by: Crispy on October 16, 2021, 08:52:12 AM
Thanks Andrew, its taken a while for various reasons , but we got there in the end.
Post by: Crispy on October 16, 2021, 08:54:48 AM
Thanks Dennis  :)
