SOHC.co.uk Forums => CB350/400 => Topic started by: llessur on April 14, 2018, 12:50:23 PM
Title: cb400F stator coil wiring
Post by: llessur on April 14, 2018, 12:50:23 PM
From the stator coil to the small harness are three yellow wires. If I understand the way it works correctly I do not think it matters which yellow wires (bullet connectors) go to which yellow wires on the small harness. Before I go and do any damage I wondered if someone in the know would mind either confirming this or setting me on the right track.
As always, thank you
Title: Re: cb400F stator coil wiring
Post by: taysidedragon on April 14, 2018, 12:58:46 PM
That's correct.  :)
Post by: llessur on April 14, 2018, 01:02:02 PM
thank you so much
...........on with the build  :)
