SOHC.co.uk Forums => CB750 => Topic started by: Spitfire on August 15, 2007, 08:05:55 PM
Title: Fired up for the first time since 1993
Post by: Spitfire on August 15, 2007, 08:05:55 PM
Well I got the new battery yesterday, I had to go to the dentist this morning so I was going to spend an afternoon checking out everything electrical then fire her up tomorrow, however our 12 year old grandson (Dean) arrived and he got very excited about starting her up, as he helped me put the frame on the engine I went along.
Took a long time to get the oil pressure light off, I put one litre of oil in the tank and one litre in the cam cover, it took a long time for the oil light to go out, so long that I started to suspect the oil pressure switch, but a look into the cam cover showed no sign of oil spraying around so I carried on. The oil light eventually went out, then I waited a few more minutes turning her over until I could see oil spraying about in the cam cover. Plugs in and she fired up on the second push of the button. I was amazed, Dean was over the moon, he's seen the bike progress from a bare frame to the finished article.
The only real snag was the ignition switch, it gave up the ghost while we were getting the oil pressure up, rather than disappoint Dean I put a jumper wire in the cable block and carried on. I later changed out the switch for the one on my F2 which works great.
Got to fit the tacho and speedo cables, change out some bulbs, fit the new registration plate, check out the horn as it isn't working and she should be ready for the road.
YIPPEE
Den
(http://i192.photobucket.com/albums/z244/DennisMcc/First%20start%20up/Firststartup005.jpg)
(http://i192.photobucket.com/albums/z244/DennisMcc/First%20start%20up/Firststartup002.jpg)
(http://i192.photobucket.com/albums/z244/DennisMcc/First%20start%20up/Firststartup003.jpg)
(http://i192.photobucket.com/albums/z244/DennisMcc/First%20start%20up/Firststartup001.jpg)
Title: Re: Fired up for the first time since 1993
Post by: dave400 on August 15, 2007, 10:23:32 PM
Now that it
Post by: mick on August 15, 2007, 11:14:33 PM
Now then Dave & Den, i'll come down to southport for a brew and look at yer bikes  ;),  Den your f1's a credit to you  8), don't it feel good when they start up after all that hard work ;), cheers mick.
Post by: dave400 on August 15, 2007, 11:52:44 PM
Bloody hell Mick, nice to hear from you again! We
Post by: Dave M on August 16, 2007, 07:49:38 AM
My 550's put to shame alongside your bikes!
Post by: mick on August 16, 2007, 10:24:37 AM
Hi Dave, Sam & the CR are down your way in september at Aintree not sure of the dates , will let you know  ;),  cheers mick.
Post by: Spitfire on August 16, 2007, 10:43:27 AM
Don't worry Dave, the photos hide all the dodgy bits ! Plus it's more important how they go rather than how they look.
Den
Post by: dave400 on August 16, 2007, 11:30:31 AM
What Den wrote!.... and Dave your 550 has one nice sounding engine for sure.
Dave
Post by: dave400 on August 16, 2007, 11:31:49 AM
Cheers Mick, I
Post by: mick on August 17, 2007, 09:43:25 AM
Hi Dave, Sam & the CR will be at Aintree on september the 16th  ;), cheers mick.
Post by: Dave M on August 18, 2007, 08:17:39 AM
I''l still be away on Holiday.
Post by: Spitfire on August 18, 2007, 12:39:43 PM
If I have the bike and gear sorted and it's not raining you could see me there, I managed to find Elite Engineering which is around there somewhere so there is every chance. These days I tend to rely a lot on my sat nav to get places, have to fit a mount on the bars or something. Just chasing down electrical problems at the moment and am determined to fix my neutral switch, it went U/S in 1978, replaced it but it was still no good, so I taped over the light. Thought I had it cracked when I found a chaffed wire under the motor and it worked great right up to the point when I started up the bike, now it's on all the time. The other snag is a dragging clutch, had to use the back brake to free it off, it works but there is a decided clunk when I put it into first and finding neutral is near impossible, time will tell, but it's not exactly brain surgery to replace the plates.
Den
Post by: dave400 on August 18, 2007, 02:21:56 PM
Den, if you have all things sorted by then, let me know and I
Post by: Spitfire on August 18, 2007, 02:45:42 PM
Your on !
Post by: dave400 on August 18, 2007, 06:46:45 PM
Your on !
That's sorted, use the old tunnel Den.
Post by: Dave M on August 19, 2007, 06:04:42 PM
Shame I'm away Dave or I'd have joined you.
Post by: dave400 on August 20, 2007, 11:52:57 PM
It'll probably be hissing down! almost every time I go out it happens ;D
Post by: Dave M on August 21, 2007, 05:47:42 PM
I haven't tried mine in the rain yet.
Mates CB750K6 used to stop when it rained due to 30 year old plug leads.
Hope mine are OK!
Post by: dave400 on August 21, 2007, 06:28:04 PM
Hope mine are OK!
I've fitted Dyna coils and ignition and the bike runs great in the rain!.....problem is I don't and it's me who stops the bike  ;D
Post by: Dave M on August 22, 2007, 07:35:05 AM
I know the feeling!
