Other Stuff => Interchangeability => Topic started by: Fenderfreak on April 16, 2018, 04:20:39 PM
Title: Cb250k down pipes
Post by: Fenderfreak on April 16, 2018, 04:20:39 PM
Anyone know if other models down pipes will fit my 71 CB250K3?
Having difficulting locating a set, mine are beyond repair as corrosion has left pits the size of the Grand Canyon.
Ta!
Title: Re: Cb250k down pipes
Post by: AshimotoK0 on April 16, 2018, 08:51:01 PM
Any pipes from CB250K/350K0 to K4 will fit but early pipes had a thinner flange at the head which fatigued so they were beefed up on later models. This means that the collets are different between early & late.. Down-pipes and silencers are rare for these bikes in the UK due to our climate and no repros for the down-pipes. I have a few but I really need to keep them for my own bikes.
Loads in the States fairly cheap  but shipping is expensive plus import duty.
This guy in Germany is a good bet...worth a try. (Germans also had a B4 which had front disc brake but same pipes)
https://www.ebay.de/itm/CB250-K3-K4-B4-CB350-Krummer-links-left-exhaust-header-pipe-Auspuff-71-73/162856829039?hash=item25eb06006f:g:UlEAAOSwBOlaX2es
Post by: Fenderfreak on April 16, 2018, 11:50:00 PM
Thanks Ash 👍
I’ll give them a go
Post by: AshimotoK0 on April 17, 2018, 07:44:09 AM
Thanks Ash 👍
I’ll give them a go
His name is Frank Dorsch and his direct email is jap2wheels@yahoo.de  Worth a try for anything CB250K
Your search string on eBay.de is CB250K CB350K Auspuff Krümmer
Hope this helps...cheers Ash
Post by: AshimotoK0 on April 17, 2018, 09:22:37 AM
This is a brilliant search string (took a bit of sussing) but you have to use a third party bidder,unless you have 'friend'in Japan  ;)  If you are using Google Chrome ..right hand click to translate to English.On LHS of page select 'New arrivals' for latest listings.
https://auctions.yahoo.co.jp/search/search;_ylt=A7dPGOUorNVaMmEAIThAPDh8?p=CB350+%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88&aq=-1&oq=&x=32&y=23&fixed=0&ei=UTF-8&tab_ex=commerce&auccat=0&slider=0
Post by: AshimotoK0 on April 17, 2018, 09:34:10 AM
You also get some bargains on this German eBay small ads. site. Most seem to ship to the UK if you ask nicely !
https://www.ebay-kleinanzeigen.de/s-cb250k/k0
The stuff is out there if you look worldwide .. sadly UK stuff usually =overprice junk  .... IMHO nowadays.
Post by: Fenderfreak on April 17, 2018, 04:26:41 PM
Thanks Ash, great resource. Now in my favourites 👍
