SOHC.co.uk Forums => CB750 => Topic started by: Simon46 on May 18, 2018, 10:51:27 PM
Title: Gauze in idle jet?
Post by: Simon46 on May 18, 2018, 10:51:27 PM
Finally had to pull carbs on my 78 as it will only run on choke and no idle. Pulled slow/ idle jets from carbs all blocked. Boiled, vinegar, lemon juice syringed now blow thru. Found a gauze filter in one of them. Not checked other 3. Is this normal?
Sent from my G8141 using Tapatalk
Title: Re: Gauze in idle jet?
Post by: Trigger on May 18, 2018, 10:57:13 PM
All late carbs have a little gauze filter  ;)
Post by: Simon46 on May 18, 2018, 11:21:31 PM
But in the jet?
Post by: Arch stanton on May 19, 2018, 01:15:47 AM
Hello Simon.
Yes my F1 had filters hidden away above the inlet needle valves.
Sean
Post by: Spitfire on May 19, 2018, 10:25:48 AM
Yep my F1 had the little filters in the inlet valves and they were all clogged, but no filters on the jets.
Post by: Simon46 on May 21, 2018, 08:07:19 PM
One of the jets I can't see daylight thru again. Really want to press gauze out as it was fine 2 days ago. Aaargh
Post by: Simon46 on May 23, 2018, 09:51:55 PM
Yay after 16hrs carb work it finally idles. Sounds like an ac cobra. Can see the attraction now. Love ir
