SOHC.co.uk Forums => CB750 => Topic started by: manya2 on November 08, 2007, 09:39:50 PM
Title: new member !
Post by: manya2 on November 08, 2007, 09:39:50 PM
I'm a new member in USA Florida w/ a 1974 750K w/8000 miles.I'll be working a bit a the time,1 it's BRAKES,need to stop ! very important.I will apreciate your help and pation.English is mine second launguage SORRY !
Title: Re: new member !
Post by: Spitfire on November 09, 2007, 12:02:56 PM
Hi Manya,
           No problem, let us know what you need, photographs can help a lot.
Den
Post by: SteveD CB500K0 on November 09, 2007, 12:37:02 PM
Welcome to the UK site Manya!
Your English is fine but if you want to talk tech you'll find more Spanish speakers here (http://www.sohc4.net/forums). Look for a guy called Raul CB750K1.
Post by: manya2 on December 17, 2007, 11:41:09 PM
I'm done w/the front brake , stops fine but some times is a bit noisy ; i'll live w/that.I would like to adjuste/calibrate/balance the carburators.I have been doing some reading and they have a tool , I think is call twinmax ! Has any body has any idea if they rent this tool some were ? thank you guys , I don't relly check on the site that often and keep on riding !
Post by: SteveD CB500K0 on December 18, 2007, 07:08:26 AM
If you want to balance the carbs, you'll need a set of vacuum gauges. I use Morgan Carbtune (Google them or try eBay).
I don't know of any other special tools.
Make sure that the carb balance is the last thing you do - timing, valves etc first! It should quiet the clutch rattle and improve low speed running.
Post by: Dangerous-Dave on December 21, 2007, 08:38:57 PM
 ;) Hi and welcome
Dave
