SOHC.co.uk Forums => CB350/400 => Topic started by: boilermaker1 on July 05, 2018, 10:33:43 PM
Title: Breather pipe
Post by: boilermaker1 on July 05, 2018, 10:33:43 PM
Can any tell me the correct routing of the breather pipe
That goes from the rocker cover to the bottom of the air
filter on a 400 4
Title: Re: Breather pipe
Post by: Nurse Julie on July 05, 2018, 10:45:32 PM
Down between the front of the carbs,  between carbs 2 and 3 and up to bottom of airbox.
Like so:
[attachimg=1]
Post by: boilermaker1 on July 05, 2018, 10:58:23 PM
Thanks for reply Julie , what type of pipe connects to bottom of airbox?
Post by: Nurse Julie on July 05, 2018, 11:15:06 PM
Its just a rubber drain tube that goes to atmosphere. 1 piece. I think originally they had a little squeeze piece that you were meant to squeeze at service to let any moisture out. I haven't got that type on mine any more, just a length of rubber tubing which does the job just fine.
