SOHC.co.uk Forums => CB500/550 => Topic started by: florence on July 22, 2018, 05:32:43 PM
Title: Missfire at low revs
Post by: florence on July 22, 2018, 05:32:43 PM
Not sure what the problem is, runs very badly, popping and misfiring and chuffing back through the carbs at low revs, drops to to 3 or 2 cylinders momentarily, but when I open up and keep above about 4000rpm it runs like a dream.  I thought it was the points because when these aftermarket points get old the timing goes all over the place.  However, installed a good used genuine set and reset ignition timing and still has exactly the same problem.
Does anyone have any ideas?
S
Title: Re: Missfire at low revs
Post by: Colonial-Clive (yindi) on July 22, 2018, 05:40:54 PM
Bad earth on coil maybe, Look at your bullet connectors make sure there not all corroded up.
Post by: florence on July 22, 2018, 06:39:36 PM
good thought, will try that.
Post by: hairygit on July 22, 2018, 07:01:33 PM
Also check where the wires from the points join the main loom, just behind the rear brake light switch. They sometimes got knocked /pulled at that junction, and make sure both parts of the bullet connectors are clean (bright and shiny) and tight.
Post by: petermigreen on July 22, 2018, 07:03:36 PM
If it's only happening at lower revs sounds like carburation issue on the idle circuit.
If it was and electrical connection, wouldn't that be an issue at any revs?
Just another opinion.
Post by: Rob62 on July 22, 2018, 09:33:26 PM
It could be ignition timing, maybe a bit retarded and at higher revs the auto advance just helps it enough? ... I’ve only ever had a similar problem on a 2t yamaha which is definitely too rich on the idle circuit, so you may be right to suspect the carbs.
Post by: Rob62 on July 22, 2018, 10:08:48 PM
Actually on thinking about it i have had a similar issue, running ok then sudden missfiring and chuffing at low revs and then springing into life at higher revs. It was on a v twin 2 stroke NSR 250 with an expensive and rare electronic ignition module and i feared the worst... But all it needed was a new pair of spark plugs and it immediately ran like a dream. A lesson in the importance of checking the cheap easy solutions first...
Post by: Bryanj on July 23, 2018, 12:14:51 AM
Plug capor lead
Post by: florence on July 24, 2018, 06:58:30 PM
OK, so checked timing again and definitely fine.  I will check the plugs and caps and leads, they are a bit of a mess, and covered in all sorts of 25 year old road dirt.... I also just realised that I cannot remember when I last took out the spark plugs.  Until recently it has just been amazingly reliable.  I will continue to investigate along these lines and report back..  Thanks for suggestions.
Post by: florence on July 29, 2018, 01:59:34 PM
OK, so looking at the coils, they are the original ones and they always go wrong in the rain so maybe should replace anyway as part of process of elimination.  Does anyone have a view about best place to get replacement coils?
Post by: Trigger on July 29, 2018, 02:59:18 PM
Have you tried snipping 5mm off each of the HT leads ? I had the same problem one, and found a small bit of corrosion on one of the lead ends. Always worth a try  ;)
Post by: florence on July 29, 2018, 04:08:32 PM
Unfortunately there isn't enough left, I've done that in the past, now they only just reach  ;D
Took off the carbs today just to make sure.  Found lots of crud in number one and thought that must have been the fault, but, I put it back together and now it runs slightly better but still cutting out on one of the cylinders every now and then.
Post by: Johnwebley on July 29, 2018, 07:20:06 PM
  I got a pair of compatables from Boyer electronics,
I had several from DSS,but they kept failing,and only 6months warrenty
  I assume its the 703, with 4ohm resistance
Post by: petermigreen on July 29, 2018, 09:52:22 PM
I used these at recommendation of Green1. No problems.
https://www.ebay.co.uk/itm/Honda-CB500-K0-K3-Four-71-74-Ignition-Coil-1-/192366027453?hash=item2cc9e8a2bd
Peter
Post by: Green1 on July 29, 2018, 10:12:05 PM
I run those on my 550 and 750 cheap as chips and work in the rain
Post by: petermigreen on July 29, 2018, 10:31:18 PM
I haven't tried mine in the rain.
Post by: Green1 on July 29, 2018, 10:33:56 PM
I'm sure you will get caught out soon.
I got the bike out this morning so its rained all day today.  ::)
Post by: paulbaker1954 on July 30, 2018, 11:47:11 AM
I have a pair of those aftermarket coils I never used as I went for Boyer full kit in the end
The mounting bolts are missing but sure that wont be a big challenge
PM me if you are interested
Post by: florence on July 31, 2018, 05:13:43 PM
PM sent,
(I love this place, thanks everyone.)
